Received: from home.com ([24.7.140.126]) by mail.rdc1.wa.home.com
(InterMail v4.01.01.00 201-229-111) with ESMTP
id <19990902062738.NTK22396.mail.rdc1.wa.home.com@home.com>
for <murphy-rebel@dcsol.com>; Wed, 1 Sep 1999 23:27:38 -0700
Message-ID: <37CDB5EA.EF8BF5EF@home.com>
Date: Wed, 01 Sep 1999 23:25:56 +0000
Reply-To: danmorehouse@home.com
X-Mailer: Mozilla 4.61 (Macintosh; I; PPC)
X-Accept-Language: en
MIME-Version: 1.0
Subject: Spring Gear SG-13 placement
Content-Type: text/plain; charset=us-ascii; x-mac-type="54455854";
x-mac-creator="4D4F5353"
Thanks for the feedback about the blocks. I'll read it in a bit. As for
now, I've got another potential growth opportunity.
I took off fus 40 and went through steps 4 thru 9 of section 16,
overlapping the bottom skin (fus 40) onto SG13 with the 3 3/8" sticking
forward past the edge of fus 40. Then in step 10 two things happened.
One, I couldn't slide SG13 all the way forward since the corners of the
piece would hit against the tapering lower rolled corners before coming
into place. So I just fitted it on the outside to see how things would
line up. This brings me to the second problem.
According to step 10, the 3 3/8" line on SG13 is supposed to be flush
with the edge on fus 7, the front floor. My line ends up over an inch
ahead of the edge of fus 7. The way I have it, my front floor edge is
flush with the back edge of the rear carrythrough and the front of fus
40 is flush with the front edge of the rear carrythrough.
I've got a couple pics I'd like to upload to Wray or Mike or just plain
send them individually.
Getting late, which is nothing new,
Dan
R280
Mike Davis
Received: from the-benson-s
(207-172-184-180.s180.tnt6.lnhva.md.dialup.rcn.com [207.172.184.180])
by smtp2.erols.com (8.8.8/8.8.5) with SMTP id QAA29186
for <murphy-rebel@dcsol.com>; Thu, 2 Sep 1999 16:07:57 -0400 (EDT)
Message-ID: <00ee01bef57d$f4648ca0$ce84a4d8@the-benson-s>
Subject: Re: Spring Gear SG-13 placement
Date: Thu, 2 Sep 1999 16:01:30 -0400
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3155.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
Date: Thursday, September 02, 1999 2:27 AM
ahead of the edge of Fus-7
good reference for where every thing should end up. I did a new
installation and not a retrofit therefore I did not have any previosly
drilled holes to use as guides as called for in step 10. Also, Since I did
not install the bungee gear brackets, the prepunched holes in Fus-40 did not
line up with any of my channels or the carrythroughs. I ended up reversing
Fus-40 and drilling new holes.
I hope that this is of some help. As Allister says "It's not easy drawing
pictures with words"
Lonnie
MIME-Version: 1.0
X-Priority: 3
I had to taper the front of both SG-13 & SG-7.One, I couldn't slide SG13 all the way forward since the corners of the
I just looked at my installation and it appears that my line is about 2"According to step 10, the 3 3/8" line on SG13 is supposed to be flush
My Fus-7 & 40 ended up in the same locations as yours. Figure - 17 is aflush with the back edge of the rear carrythrough and the front of fus
Lonnie
Mike Davis
Received: from [154.5.73.235] (helo=ip235.toronto7.dialup.canada.psi.net)
by smtp2.interramp.com with smtp (Exim 1.90 #1)
for murphy-rebel@dcsol.com
id 11MkCK-0001d6-00; Thu, 2 Sep 1999 23:39:33 -0400
Mime-Version: 1.0
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Message-Id: <E11MkCK-0001d6-00@smtp2.interramp.com>
Date: Thu, 2 Sep 1999 23:39:33 -0400
Lonnie, it would really be great if you could bring a few pictures of
your Rebel mods along to the builders meeting !!
Thanks !!!
----------------------------orig.----------------------------------------
Mime-Version: 1.0
Thanks !!!
not-----Original Message-----
The way I have it, my front floor edge isMy Fus-7 & 40 ended up in the same locations as yours. Figure - 17 is aflush with the back edge of the rear carrythrough and the front of fus
Lonnie
Mike Davis
id <19990903051940.HMWH22396.mail.rdc1.wa.home.com@home.com>
for <murphy-rebel@dcsol.com>; Thu, 2 Sep 1999 22:19:40 -0700
Message-ID: <37CEF77C.6BFF719D@home.com>
Date: Thu, 02 Sep 1999 22:17:34 +0000
MIME-Version: 1.0
Subject: re: Spring Gear SG-13 placement
Thanks, Lonnie!
Dan
MIME-Version: 1.0
Thanks, Lonnie!
aMy Fus-7 & 40 ended up in the same locations as yours. Figure - 17 is
I feel like I'm on track.good reference for where every thing should end up
Dan
Mike Davis
Spring Gear SG-13 Placement
Received: from aws1.bp.nrl.navy.mil [132.250.13.17]
(HELO localhost)
by alpha1.tf.bp.nrl.navy.mil (AltaVista Mail V2.0J/2.0J BL25J listener)
id 0000_0056_37d4_ef8b_3bd0;
Tue, 07 Sep 1999 06:57:15 -0400
Received: by bpvax.tf.bp.nrl.navy.mil (UCX V4.2-21, OpenVMS V7.1 VAX);
Tue, 7 Sep 1999 10:57:54 -2359
Message-ID: <039901bef91f$c431e820$b300a8c0@tf.bp.nrl.navy.mil>
Subject: Spring Gear SG-13 Placement
Date: Tue, 7 Sep 1999 06:57:15 -0400
MIME-Version: 1.0
X-Priority: 3
X-Mailer: Microsoft Outlook Express 5.00.2014.211
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2014.211
I've also placed 2 photos from Dan Morehouse regarding Spring Gear SG-13
Placement at the following URL...
http://www.dcsol.com/murphy-rebel/galle ... /page2.htm
Here are descriptions to go with each photo...
Fus40fus7.jpg just shows the orientation of these two pieces. I had
questioned
it since things didn't seem to be working out.
In SG13.jpg, the flash washed out the word 'bolt'. The line is the 3 3/8"
line.
The vertical rivet line is centered on the rear carrythrough. The upper
right
hand corner apparently needs to be trimmed to fit inside the rolled corner.
(HELO localhost)
MIME-Version: 1.0
X-Priority: 3
questioned
line.
right
