props
Props
Post by Bob Patterson » Fri Feb 17, 2012 11:12 pm
Thanks Dale !! Sounds like you've got a winner !!!
Does the prop require re-torquing regularly, like all
wood props, or does the carbon fiber coating avoid that ??
----------------------------orig.-------------------------------
At 10:39 AM 6/21/03 -0500, you wrote:
Murphy pilots,
Here are the test results using a new overhauled Sensenich and a Prince
wood/carbon fiber prop(bought from Colleen at Murphy}.
The Sensenich with spacer and hardware 38lbs, Prince 13lbs with the same
spacer and hardware.
Static thrust, Sensenich 450/2400rpm, Prince 505/2300rpm.
The Prince prop averaged 70fpm rate of climb better than the Sensenich.
Full power, they both indicated 115mph/2600rpm.
My plane has a 160hp Lycoming on amphibious floats.
Dale N295RT
Dale Kopff
props
Post by Dale Kopff » Fri Feb 17, 2012 11:12 pm
Rebel pilots,
The Sensenich was a 74-56, and the Prince a74-44. I questioned the 44 pitch
and was told because off the P-tips semitar shape, and because the blades
cone under a load, it changes pitch. It does work!
I do not know if I will need to re-torque the prop
, but plan on checking it out.
Prince prop has a site for better information, www.princeaircraft.com.
They have made over 6000 props in the last 22 years.
Props
Post by Drew Dalgleish » Fri Feb 17, 2012 11:12 pm
At 10:39 AM 6/21/2003 -0500, you wrote:
Murphy pilots,
Dale N295RT
Cool Dale Is that a 2or3 blade prop? Does it have any leading edge
protection to prevent water erosion on floats?
rebel
props
Post by rebel » Fri Feb 17, 2012 11:12 pm
On 6/22/2003 5:27 AM, DKOPFF@EARTHLINK.NET wrote to MURPHY-REBEL:
How does the engine idle with the lighter prop and will this prop have the same
cracking issues that the Warp Drive props have had?
Rick D.
-> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.7)
-> for murphy-rebel@dcsol.com; Sat, 21 Jun 2003 12:46:18 -0800
-> Received: from mallard.mail.pas.earthlink.net ([207.217.120.48])
EHLO=mallard.mail.pas.earthlink.net
-> by dcsol.com (Wildcat! SMTP v5.6.450.7) with SMTP
-> id 68610750; Sat, 21 Jun 2003 12:46:16 -0800
-> Received: from ppp053193.usmo.com ([209.248.53.193] helo=dkopff)
-> by mallard.mail.pas.earthlink.net with smtp (Exim 3.33 #1)
-> id 19TpFW-0003cF-00
-> for murphy-rebel@dcsol.com; Sat, 21 Jun 2003 13:46:15 -0700
-> Message-ID: <000001c33836$1be6b600$c135f8d1@dkopff>
-> Reply-To: "Dale Kopff" <dkopff@earthlink.net>
-> From: "Dale Kopff" <dkopff@earthlink.net>
-> Subject: props
-> Date: Sat, 21 Jun 2003 15:44:26 -0500
-> X-Orig-MIME-Version: 1.0
-> X-Orig-Content-Type: text/plain; charset="iso-8859-1"
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 5.50.4133.2400
-> X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4133.2400
-> Rebel pilots,
-> The Sensenich was a 74-56, and the Prince a74-44. I questioned the 44 pitch
-> and was told because off the P-tips semitar shape, and because the blades
-> cone under a load, it changes pitch. It does work!
-> I do not know if I will need to re-torque the prop
-> , but plan on checking it out.
-> Prince prop has a site for better information, www.princeaircraft.com.
-> They have made over 6000 props in the last 22 years.
Dale Kopff
Props
Sent: Saturday, June 21, 2003 4:30 PM
Subject: Re: Props
Murphy pilots,
Dale N295RT
Drew,
I have a two blade, and if there is any leading edge protection, it would be
under the carbon fiber finish.
Lonnie Prince has said I could have better performance if I would have
ordered a larger diameter prop.
Does anyone know what is the largest prop that can be used on a amphibious
rebel?
I will be selling my new overhauled Sensenich 74-56 prop, and I also have a
13" 3 blade aluminum spinner for sale.
Dale
Dale Kopff
props
Sent: Sunday, June 22, 2003 8:29 AM
Subject: RE: props
same
Rick D.
Rick,
I can not tell any difference between props at idle.
Because the prop has a wood core, there is a life time waranty from
cracking.
Dale
-> Subject: props
-> X-Priority: 3
-> Rebel pilots,
pitch
blades
Props
Hi Dale !
You can go to 76" with no problems .... not sure
about longer (there's clearance, but Lycoming might have other
ideas !). ;-)
---------------------------------orig.----------------------------------
Subject: Re: Props
Murphy pilots,
Dale N295RT
Drew,
rebel?
Dale
Props
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:12 pm
82" Borer props are certified for O-320's, so that's a diameter that's okay.
There is a >LOT< more room than that if your floats are mounted per MAM's
drawings, but sure wouldn't be a quiet thing at 2600 RPM now would it??
Sent: Sunday, June 22, 2003 3:32 PM
Subject: Re: Props
Hi Dale !
ideas !). ;-)
Subject: Re: Props
Prince
same
Sensenich.
Drew,
be
amphibious
rebel?
Dale
Dale Kopff
props
Post by Dale Kopff » Fri Feb 17, 2012 11:58 pm
I have replaced my sensenich prop with a Prince (wood/carbon fiber) prop. It
outperforms the sensenich prop in thrust, rate of climb and is 22 lbs.
lighter.
The cruise speed is the same.
Dale
Rebel (160 hp) N295RT
props
Post by Walter Klatt » Fri Feb 17, 2012 11:58 pm
Dale, could you also tell us what diameter and pitch of the new
prop you are using? And what is your static or take-off RPM? Can
you hit 2700 in full throttle straight and level?
Sent: Monday, November 10, 2003 1:52 PM
Subject: Re: props
Dale, which model Sensenich did you remove, the newer
DM wide chord tip
style or the older tapering/rounded tip style??
Sent: Monday, November 10, 2003 11:22 AM
Subject: props
It
lighter.
Dale
Archives located at
Archives located at
props
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:58 pm
Dale, which model Sensenich did you remove, the newer DM wide chord tip
Subject: props
It
lighter.
Dale
Dale Kopff
props
Sent: Monday, November 10, 2003 3:52 PM
Subject: Re: props
The prop removed was a DM 74-56, just overhauled.
Subject: props
prop.
It
lighter.
Dale
props
What's the pricing on the Prince Prop?? Sounds like maybe the way to go to
achieve the lightness of the Warp Drive and the Performance of the big metal
club!
Sent: Tuesday, November 11, 2003 3:19 PM
Subject: Re: props
Subject: Re: props
Subject: props
prop.
It
lighter.
Dale
Legeorgen
props
Post by Legeorgen » Fri Feb 17, 2012 11:58 pm
Dale,
How interesting about your Prince prop out performing the Sensenich. The
22lb. not hanging way out front of the C&G is enough of a plus on its own! Have
any more detail on the specs? I suppose the only real draw back would be its use
on a float plane, being wood and composite. tell use more.
Bruce
Dale Kopff
props
Post by Dale Kopff » Sat Feb 18, 2012 12:00 am
Sent: Tuesday, November 11, 2003 4:20 PM
Subject: Re: props
metal
club!
I bought the prince prop through Coleen at Murphy.
The cost was around $1,800.00 which included leading edge protection for sea
use.
Prince has been making props for over 25 years, currently about 300 props a
year, including the props for the military on the predator unmaned aircraft.
Dale
Subject: Re: props
Subject: Re: props
tip
Subject: props
prop.
It
lbs.
