Gullwing doors?
Gullwing doors?
Post by Walter Klatt » Fri Feb 17, 2012 10:56 pm
When on floats, I stand on the front end of my strut
step support and hang on to the top sill of my door
with one hand when checking my fuel. I can fuel it that
way, too, without any ladder or other support. So not
sure if that would still work if they were gull wing
doors.
lisafly99@aol.com
Sent: Sunday, April 20, 2003 7:52 PM
Subject: Re: Gullwing doors?
Any input on gull wing doors on the Rebel
would be greatly appreciated. I'm
sure someone out there has done it. Pros&Cons please.
Phil&Lisa Smith
#460R
N414D
And working on another one.
http://www.dcsol.com:81/public/code/html-subs
cribe.wcx
Archives located at
LisaFly99
Gullwing doors?
Post by LisaFly99 » Fri Feb 17, 2012 10:56 pm
Any input on gull wing doors on the Rebel would be greatly appreciated. I'm
Phil&Lisa Smith
#460R
N414D
Brian Lawson
Gullwing doors?
Post by Brian Lawson » Fri Feb 17, 2012 10:56 pm
Hey Phil and Lisa,
I know that Curt (Rebel 426 N97MR<Rebflyer@aol.com>) has cabin doors
that are hinged at the top, and when opened they latch and lay flat
against the underside of the wings. His plane is an amphib, and he
says that this greatly facilitates getting in and out of the plane to
and from the floats during water work. I forget what he did with his
wing tank-drains.
Curt wrote earlier today that he was going to be U/S for a bit while
he has some medical work done, but I'm sure when he comes back he
would put forth at least the "pro" argument.
Take care. Happy Easter.
Brian Lawson,
Windsor, Ontario.
XXXXXXXXXXXXXXXXXXXXXXXXX
I'm
Phil&Lisa Smith
#460R
N414D
wrayt
Gullwing doors?
Post by wrayt » Fri Feb 17, 2012 10:56 pm
If you go down near the bottom of this page there are 3 pictures
of Curt's Door http://wrayt.tripod.com/construction.html
Wray Thompson ...Rebel 306 ...home page http://wrayt.tripod.com/
My ICQ number is 29764664
LisaFly99
Gullwing doors?
In a message dated 4/22/03 7:58:35 AM Central Daylight Time, wrayt@dcsol.com
writes:
WRAY
Thanks, I have you're page saved, but forget the wealth of info it holds. I
need to get a good look at the door mod for strut clearance. So I'll just put
the doors on hold for now. Thanks for the help.
Phil&Lisa Smith
#460R
N414D
Jones, Michael
Gullwing doors?
Post by Jones, Michael » Fri Feb 17, 2012 10:56 pm
Phil & Lisa
i am currently doing my doors gull wing with opening window, with outside
locking paddle latch (like cessna, sorry for the bad word)and internal hand
crank
will post picks in next few weeks, hopefully
at this point i would say its a hell of alot of design and fabrication work,
months and months of sketches and redesign, should be great when done
however
one problem however is you cant reach the inside door handle when door is in
the up position, need anther handle somewhere on the door, its almost done
but still few small details to work out, might put gas cylinder on it to
raise door as well
can bring door to next meeting at brampton if are close enough to get to
brampton, otherwise you will have to wait for the pics
regards
Mike#007
Sent: Tuesday, April 22, 2003 9:17 AM
writes:
WRAY
put
Phil&Lisa Smith
#460R
N414D
LisaFly99
Gullwing doors?
In a message dated 4/22/03 9:53:44 AM Central Daylight Time, MJones@hatch.ca
writes:
raise door as well
MIKE
Thanks for the reply. I can't make Brampton, I live states. I also thought of
a gas cylinder. How is the clearance on the front bottom of the door to the
strut? It looks like it would have to be reshaped shorter in that area.
Phil&Lisa Smith
#460R
N414D
Jones, Michael
Gullwing doors?
Phil&Lisa
yes you must reshape ar front of door to clear strut, can give you dims when
& if you need, can also post drawing of how my door works when done, but its
lota of extra work
mike#007
Sent: Tuesday, April 22, 2003 9:28 PM
writes:
raise door as well
MIKE
Phil&Lisa Smith
#460R
N414D
Rebflyer
Gullwing doors?
Post by Rebflyer » Fri Feb 17, 2012 10:56 pm
Hi Phil, the additional wedge you'll need in the front of the door is 11.5"
long and 2.5" high. That left me enough room for a 1/2" overlap of the door
skin to fusealage and the wedge takes so little of the door space you won't
even notice it when you get in and out. I have always been able to stand on
my step and check fuel without hanging on to anything, but my step is 2.5"
wide. I really cannot give any real arguments of gullwing vs std. doors as I
have only flown with the gullwings. I do think it would be nice to open a
window in flight, but the doors do float nicely when left open. I''ve never
flown with them in the open and latched position as I'm concerned that the
narrowing thickness of the door to wing distance may cause some fluttering or
losss of lift and the door is only about 3/4 away from the wing in the rear.
If I want to I can have the doors off in about 10 min. I also went to the low
profile sump drains and there is plenty of room between the door and sump
that way. My ventilation is from a couple of cessna style flap vents borrowed
from a 150. They work great.
All in all, the doors are great on floats. Easy access and its easy to
have the passenger hang onto the strut until the prop stops wihtout dodging
the door, but I'm not sure if that is even a real problem. Sooo keep at it,
it's worth it! Curt N97MR
Jones, Michael
Gullwing doors?
curt
if you come to next meeting i can show you my gull wing door, with opening
widow, its pretty slick, although alot of the credit for it must go to
william yaworski of stoney creek, his concept
mike#007
Sent: Thursday, April 24, 2003 12:29 PM
or
low
borrowed
Rebflyer
Gullwing doors?
Thanks. Has William got his flying yet or is he still making mods?
Jones, Michael
Gullwing doors?
he is still amking mods, doing lots on the doors, the poor soul, head he got
his windshield in how hoever, must admit its a really class a job he has
done on it, its perfect i would say
mike#007
Sent: Thursday, April 24, 2003 12:53 PM
rebel007r
Gullwing doors?
Post by rebel007r » Fri Feb 17, 2012 11:58 pm
i mike here rebel 007, have you seen my pictures on the
serever of my doors, any help to you
mike#007
On 10/24/2003 3:15 AM, LISAFLY99@AOL.COM wrote to MURPHY-REBEL:
-> From <LisaFly99@aol.com> Tue, 22 Apr 2003 17:28:18 -0800 remote from
dcsol.com
-> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.61)
-> for murphy-rebel@dcsol.com; Tue, 22 Apr 2003 17:28:18 -0800
-> Received: from imo-m05.mx.aol.com ([64.12.136.8]) EHLO=imo-m05.mx.aol.com
-> by dcsol.com (Wildcat! SMTP v5.6.450.61) with SMTP
-> id 85456640; Tue, 22 Apr 2003 17:28:16 -0800
-> Received: from LisaFly99@aol.com
-> by imo-m05.mx.aol.com (mail_out_v34.22.) id b.172.1989f0a5 (2168)
-> for <murphy-rebel@dcsol.com>; Tue, 22 Apr 2003 21:28:23 -0400 (EDT)
-> From: LisaFly99@aol.com
-> Message-ID: <172.1989f0a5.2bd74637@aol.com>
-> Date: Tue, 22 Apr 2003 21:28:23 EDT
-> Subject: Re: Gullwing doors?
-> To: murphy-rebel@dcsol.com
-> X-Orig-MIME-Version: 1.0
-> X-Orig-Content-Type: multipart/alternative;
boundary="part1_172.1989f0a5.2bd74637_boundary"
-> X-Mailer: 8.0 for Windows sub 6011
-> In a message dated 4/22/03 9:53:44 AM Central Daylight Time,
MJones@hatch.ca
-> writes:
-> > might put gas cylinder on it to
-> > raise door as well
-> > can bring door to next meeting at brampton if are close enough to get to
-> > brampton, otherwise you will have to wait for the pics
-> MIKE
-> Thanks for the reply. I can't make Brampton, I live states. I also thought
-> a gas cylinder. How is the clearance on the front bottom of the door to the
-> strut? It looks like it would have to be reshaped shorter in that area.
-> Phil&Lisa Smith
-> #460R
-> N414D
