Run that one by me again. What's the formula? I've never heard that
stated before. Very interesting though!!
Thanks.
Brian Lawson,
Bothwell, Ontario.
ps.... anybody ever use the grass strip closest to me, the field at
Highgate, CNA2? WUZZIT like? Good for a Rebel?
XXXXXXXXXXXXXXXXXXXXXXXXXX
On Thu, 14 Aug 2003 16:13:28 -0400, you wrote:
I would guess that when we see the rotax V6 numbers, at least some folks
will decide that it blows the doors off a 300 hp Lycoming on an SR.
Somewhat like a 912 tends to perform better than most equivalent rated
Lycosaurs on a Rebel. The larger slow turning prop will give more
takeoff thrust per hp. The turbo likely means no reduction in takeoff
power due to altitude to at least a few thousand feet.
From Bob's comments, if the normally aspirated engine is only burning
11gph at .42 sfc then it is only making 11 gph * 6 lb/gal / .42 hp-hr/lb
= 157 hp.
Off the top of my head I would guess that at 18 gph the radial engine is
goodmaking about 215 hp. leaned out. Is that in the ballpark?? If it is
getting the same cruise speed, that will give an indication of the
difference. More efficient prop, a lot less cooling drag, significantly
less fuel weight for an equivalent mission, etc.
Not sure its fair to compare that
larry173 wrote:Exactly we need a 350 to 400 hp At this point LS1, Ls^ is our only
alot ofoption. Rumers are of a V8 400hp Bombi but in about 5 years.
Sent: Wednesday, August 13, 2003 11:36 PM
Subject: Re: New at Murphy
why 300HP? It seems they would go for higher HP. There seems to be
lacking onoffering aengines around 300 but alot fewer at 350-400. Is it because they are
certified replacement for the 540-550 class engine? Seems to be
--*the
moose though.
Brad
--*To unsubscribe from this list go to:
