Engine mounting nuts / bolts
Post by Ralph Baker » Fri Feb 17, 2012 11:15 pm
First a word of caution. If you are picking up your Lycoming O-360 (and
I presume O-320) oil pressure at the right rear oil gallery plug just
inboard of the upper right Dynafocal mount cup it is mandatory to screw
in the 45 degree restrictor fitting BEFORE you mount the engine on the
Dynafocal mount. It also needs to point more or less down and to the
left. Please don't ask how I discovered this.
While rectifying the above I used the the MAM supplied bolts and all
metal self locking nuts and further discovered that it will take (for my
mount / rubbers / engine) that a total of 3 washers are required to
prevent the nut bottoming on the bolt shank. Since this is only
discovered after the fact, the nuts had to be removed to add the
additional washer(s).
That leads to the following question. Is it permissible, i.e.
reasonable practice, to reuse the metal self locking nuts and/or bolts
once, provided they seem to have sufficient remaining assembly torque or
would it be prudent to replace the nuts or both bolt and nut.
Thank you for your considered opinions,
Elite 624E
rebel
Post by rebel » Fri Feb 17, 2012 11:15 pm
On 7/27/2003 5:08 PM, REBAKER@FTC-I.NET wrote to MURPHY-REBEL:
Ralph, Mike Davis, and others,
I posted a couple of pics of my oil press fitting. I too wrestled with
this a little before finally getting it right.
Mike, I posted the second picture to the wrong section could you please move
it over to the rebel engine section. Thanks.
Rick D.
-> First a word of caution. If you are picking up your Lycoming O-360 (and
-> I presume O-320) oil pressure at the right rear oil gallery plug just
-> inboard of the upper right Dynafocal mount cup it is mandatory to screw
-> in the 45 degree restrictor fitting BEFORE you mount the engine on the
-> Dynafocal mount. It also needs to point more or less down and to the
-> left. Please don't ask how I discovered this.
-> Thank you for your considered opinions,
-> Ralph Baker
-> Elite 624E
Murray and Carol Cherkas
Post by Murray and Carol Cherkas » Fri Feb 17, 2012 11:15 pm
All you guys had to do was buy a conical mount.
No Name
rebel@dcsol.com
Sent: Sunday, July 27, 2003 6:12 PM
Subject: RE: Engine mounting nuts / bolts
move
Rick D.
-> Ralph Baker
-> Elite 624E
klehman
Post by klehman » Fri Feb 17, 2012 11:15 pm
Bingelis says that even the nylon insert locknuts can be used many times
as long as they still grip.
Ralph Baker wrote:
snip
