Radio transmition
Legeorgen
Radio transmition
Post by Legeorgen » Fri Feb 17, 2012 11:15 pm
Walter,
It could be all that water you fly in has corroded your antenna ground plane.
Try taking your antenna off and clean the connection where it makes contact
with the fuselage skin.
Bruce
Radio transmition
Post by Walter Klatt » Fri Feb 17, 2012 11:15 pm
I haven't had a chance to check things yet, but was
thinking too about the antenna. However, depending on
my squelch setting, I do know that I pick up
transmissions 50 and more miles away, so would think
the antenna would have to work for that. I do remember,
though, putting a lot of effort into cleaning the paint
off for mounting and sealing off the outside. And I
don't store it outside in the rain.
I had problems some time ago with a noise filter, and
installed a new one, but in a different location. You
are supposed to put it as close to your alternator as
possible, which I had before, but the old one got beat
apart there, probably from the heat and vibration. So
then I mounted it on the firewall, and maybe more noise
is now getting through to the radio. However, it does
not affect receiving, just transmitting. Anyway, this
will be the first thing for me to try and see if it
works. I am no expert at radios either, so I may have
trouble getting this one fixed.
Legeorgen@aol.com
Sent: Wednesday, July 02, 2003 7:46 AM
Subject: Re: Radio transmition
Walter,
Bruce
cribe.wcx
Archives located at
Radio transmition
Thanks, Nigel. I live in the Vancouver area, not far
from Chilliwack, actually.
There are a few things I need to check as soon as I
have a chance, and I appreciate the leads.
N.Smith
Sent: Wednesday, July 02, 2003 11:21 PM
Subject: RE: Radio transmition
Hi Walter (and all)
I'm a radio ham in what spare time I've got
left after working on my Elite,
and I agree the antenna problem would
account for a loss in receive as well
as transmit, but it's surprising how well a
bad antenna can still receive.
You really need to test the antenna only, by
connecting it to a test box to
convince yourself one way or the other about
the antenna. Have a look in
your local area for ham radio or amateur
radio clubs if you don't know
anyone who does this. Your ideally after an
antenna analyser (by MFJ) or
even an SWR meter from a CB type radio setup
will work at aircraft powers to
give you some idea.
Another possibility may be the power supply
to the radio , as you will need
to draw more power to transmit than receive,
and if you have a bad
connection or some other resistance in the
line it will receive fine, but
not be able to run full power on transmit.
If you let me know where you are, I'll try
to find a contact for a local
club for you if you get stuck.
Good Luck
Nigel
Elite 745E
Sent: 03 July 2003 01:44
do remember,
cleaning the paint
one got beat
more noise
Legeorgen@aol.com
Walter,
Bruce
cribe.wcx
Archives located at
cribe.wcx
Archives located at
Archives located at
N.Smith
Radio transmition
Post by N.Smith » Fri Feb 17, 2012 11:15 pm
Hi Walter (and all)
I'm a radio ham in what spare time I've got left after working on my Elite,
and I agree the antenna problem would account for a loss in receive as well
as transmit, but it's surprising how well a bad antenna can still receive.
You really need to test the antenna only, by connecting it to a test box to
convince yourself one way or the other about the antenna. Have a look in
your local area for ham radio or amateur radio clubs if you don't know
anyone who does this. Your ideally after an antenna analyser (by MFJ) or
even an SWR meter from a CB type radio setup will work at aircraft powers to
give you some idea.
Another possibility may be the power supply to the radio , as you will need
to draw more power to transmit than receive, and if you have a bad
connection or some other resistance in the line it will receive fine, but
If you let me know where you are, I'll try to find a contact for a local
Good Luck
Nigel
Elite 745E
Legeorgen@aol.com
Walter,
Bruce
cribe.wcx
Archives located at
Radio transmition
Yup, tried that, but that's not it.
My first step is to relocate the noise filter back to
the alternator and see if that helps. I started that
last night and should finish tonight, so will try it
again this weekend. Got a gang of people out at our
cottage again this weekend, so it will be busy.
When I was under the cowl, I noticed a couple of tiny
cracks starting again on my right exhaust pipe near
where the cross-over joins. Same one as I got welded
last year near the same spot. So I will have to get
that fixed again before my upcoming trips. I got the
old, old mild steel exhausts that MAM used to sell many
years ago. Looks like I may have to spring for the new
stainless ones that all you guys now have. With the
rising loonie, I'm hoping the price will drop a bit.
What next? Why couldn't these problems show up a few
months ago. Oh well, better now than when I'm 1000
miles from home.
legeorgen@aol.com
Sent: Friday, July 04, 2003 6:58 AM
Walter,
Have you tried another head set? Maybe your
mic is bad
Bruce
cribe.wcx
Archives located at
Legeorgen
Radio transmition
Walter,
Have you tried another head set? Maybe your mic is bad
Bruce
Angus McKenzie - McKenzie
Radio transmition
Post by Angus McKenzie - McKenzie » Fri Feb 17, 2012 11:15 pm
Hi Walter
I have the same right side "y" pipe crack as you on 049R.It is an older mild
steel Murphy system.Fixed it 2yrs ago then put a stainless patch over the
section 3wks ago.Yesterday I spoke to the "stainless guy"and he is going to
make me a complete 2" system using my old 0-290 engine for a template.He
does not work in 1-3/4"material and the guys in the engine shop at Leavens
said 2" was no problem.I already had a bunch of new stainless Lycoming
flanges and then it will go 1-3/4"for stud clearance and step to 2".I'll let
you know how it turns out.........Angus
yeom
Radio transmition
Post by yeom » Fri Feb 17, 2012 11:15 pm
Hi Walter,
A thought on your exhaust problems, my old exhaust system
cracked in the same place more than once, it only came right after I put the
new system in they now use to support the exhaust ( it all hangs off the
back of the engine ).
Do you have this? Mine is really good now.( and I didn't have to buy the SS
system)
Alister
Sent: Saturday, July 05, 2003 2:23 AM
miles from home.
legeorgen@aol.com
Walter,
mic is bad
Bruce
cribe.wcx
Archives located at
ray.mason
Radio transmition
Post by ray.mason » Fri Feb 17, 2012 11:15 pm
Hi Walter
If you are going to use your handheld hook it up to your external antenna, you
will notice a hugh difference.
Ray
On 7/8/2003 9:11 PM, WALTER.KLATT@SHAW.CA wrote to MURPHY-REBEL:
-> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.7)
-> for murphy-rebel@dcsol.com; Wed, 02 Jul 2003 17:52:46 -0800
-> Received: from shawidc-mo1.cg.shawcable.net ([24.71.223.10])
EHLO=pd6mo1so.prod.shaw.ca
-> by dcsol.com (Wildcat! SMTP v5.6.450.7) with SMTP
-> id 232473578; Wed, 02 Jul 2003 17:52:43 -0800
-> Received: from pd4mr4so.prod.shaw.ca
-> (pd4mr4so-qfe3.prod.shaw.ca [10.0.141.215]) by l-daemon
-> (iPlanet Messaging Server 5.2 HotFix 1.16 (built May 14 2003))
-> with ESMTP id <0HHF00HLVBB599@l-daemon> for murphy-rebel@dcsol.com; Wed,
-> 02 Jul 2003 18:42:41 -0600 (MDT)
-> Received: from pn2ml8so.prod.shaw.ca
-> (pn2ml8so-qfe0.prod.shaw.ca [10.0.121.152]) by l-daemon
-> with ESMTP id <0HHF0022ZBB569@l-daemon> for murphy-rebel@dcsol.com; Wed,
-> Received: from user (h24-82-18-134.vs.shawcable.net [24.82.18.134])
-> by l-daemon (iPlanet Messaging Server 5.2 HotFix 1.16 (built May 14 2003))
-> with SMTP id <0HHF004IOBB4N1@l-daemon> for murphy-rebel@dcsol.com; Wed,
-> Date: Wed, 02 Jul 2003 17:43:32 -0700
-> From: Walter Klatt <walter.klatt@shaw.ca>
-> Subject: RE: Radio transmition
-> In-reply-to: <12f.2d4b9573.2c344a2a@aol.com>
-> To: murphy-rebel@dcsol.com
-> Message-id: <PFEOJDIIGOHLFACHDMDNGEPGCHAA.Walter.Klatt@shaw.ca>
-> X-Orig-MIME-version: 1.0
-> X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1165
-> X-Mailer: Microsoft Outlook IMO, Build 9.0.2416 (9.0.2911.0)
-> X-Orig-Content-type: text/plain; charset=iso-8859-1
-> X-Orig-Content-transfer-encoding: 7BIT
-> Importance: Normal
-> X-Priority: 3 (Normal)
-> X-MSMail-priority: Normal
-> I haven't had a chance to check things yet, but was
-> thinking too about the antenna. However, depending on
-> my squelch setting, I do know that I pick up
-> transmissions 50 and more miles away, so would think
-> the antenna would have to work for that. I do remember,
-> though, putting a lot of effort into cleaning the paint
-> off for mounting and sealing off the outside. And I
-> don't store it outside in the rain.
-> I had problems some time ago with a noise filter, and
-> installed a new one, but in a different location. You
-> are supposed to put it as close to your alternator as
-> possible, which I had before, but the old one got beat
-> apart there, probably from the heat and vibration. So
-> then I mounted it on the firewall, and maybe more noise
-> is now getting through to the radio. However, it does
-> not affect receiving, just transmitting. Anyway, this
-> will be the first thing for me to try and see if it
-> works. I am no expert at radios either, so I may have
-> trouble getting this one fixed.
-> Walter
-> > From: mike.davis@dcsol.com
-> > [mailto:mike.davis@dcsol.com]On Behalf Of
-> > Legeorgen@aol.com
-> > Sent: Wednesday, July 02, 2003 7:46 AM
-> > To: murphy-rebel@dcsol.com
-> > Subject: Re: Radio transmition
-> > Walter,
-> > It could be all that water you fly in has
-> > corroded your antenna ground plane.
-> > Try taking your antenna off and clean the
-> > connection where it makes contact
-> > with the fuselage skin.
-> > Bruce
-> > To unsubscribe from this list go to:
-> > http://www.dcsol.com:81/public/code/html-subs
-> > cribe.wcx
-> > Archives located at
-> > http://rebel:builder@www.dcsol.com:81/default.htm
-> > To contact the list admin, e-mail
-> > mike.davis@dcsol.com
