0-235 Rebel Battery Box Location
Newcog
Post by Newcog » Fri Feb 17, 2012 11:08 pm
I am slowly putting R200 together. I would like a concessus of how far aft
to locate the battery. I am a long way (time wise) from mating the wings
(space problem) and doing a weight and balance.
My Rebel has an 0-235, Warp Dr prop, aluminum cowl and standard firewall
location.
I am looking for experienced estimates from any other 0235 Rebel builders.
Norm Wandke
Legeorgen
Post by Legeorgen » Fri Feb 17, 2012 11:08 pm
Hi Norm,
With an 0235 and a WD prop I would think the battery could be located on the
firewall without a forward CG problem. Save the weight of a large cable
running forward and keep the fuselage floor clean.
I waited to locate my battery until I had the plane assembled and weighed.
Then I worked out a few different locations for the battery to arrange the CG
where I wanted it. It worked out really well but I have an 0320 with a heavy
Sensenich prop and original firewall.
You should not have a problem with the battery on the firewall with your
configuration
Bruce 357R.
Post by Bob Patterson » Fri Feb 17, 2012 11:08 pm
Hi Norm !
You should have no problem mounting the battery on the
firewall. If you use a lightweight B&C starter, you can spin it
fast enough to taxi with a lightweight motorcycle battery !!
Suggest using an Oddysey lightweight battery - then you can use
a light Lexan box for the battery, as one of our Rebels with an O-235
here did. The Oddysey (sp ??) batteries do not need a drain pipe !
If you really want to put it in back, get one of the narrow
versions of Oddysey, and mount it on the right side lip of the
fuselage just behind the baggage area 'curtain'. By putting it up
on top of the inside corner wraps, you leave the floor flat for
sleeping. ;-)
Keep going - It IS worth it !!! :-) :-)
--------------------------------orig.------------------------------------
location.
Norm Wandke
Hi Steve !
I'm sure it's in the archives - try a search on keyword
battery or Odysey ..... I think there was one for BC, and another
from Ontario.
At 04:10 PM 5/27/03 +0000, you wrote:
Hi Bob
If u are in Canada, do u have a supplier for the Odesey batteries?
Steve W
#637
Subject: Re: 0-235 Rebel Battery Box Location
Date: Tue, 27 May 2003 09:44:14 -0400
Hi Norm !
sleeping. ;-)
aft
location.
builders.
Norm Wandke
Add photos to your messages with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:08 pm
Here's the link to Great Northern Battery Systems.
http://www.absolutebattery.com/odyssey.htm
They have a location in Hamilton Ontario and Dartmouth Nova Scotia
Sent: Tuesday, May 27, 2003 1:11 PM
Hi Steve !
from Ontario.
Hi Bob
Steve W
#637
Hi Norm !
sleeping. ;-)
far
aft
wings
firewall
builders.
Post by Walter Klatt » Fri Feb 17, 2012 11:08 pm
In Vancouver, BC, you can get them at Polar Battery.
http://www.polarbattery.com
Sent: Tuesday, May 27, 2003 10:42 AM
Hi Steve !
from Ontario.
Hi Bob
Steve W
#637
far
wings
firewall
cribe.wcx
Archives located at
___________
FREE*.
Archives located at
Archives located at
Archives located at
steve whitenect
Post by steve whitenect » Fri Feb 17, 2012 11:08 pm
Hi Bob
Steve W
#637
Hi Norm !
sleeping. ;-)
aft
location.
builders.
Norm Wandke
Rick Harper
Post by Rick Harper » Fri Feb 17, 2012 11:08 pm
G'day Norm !
We put an Odyssey (I think thats how it's spelt) battery right up on
the firewall with our 0-235 .... and the balance worked out well with a
wood prop (only weighs about 7 lbs) .... when we fitted the metal prop,
we put a 10 lb bag of lead shot pellets in the last section of the
fuselage to offset the extra weight up front .... and she flies & lands
GREAT ! :-)
Currently in the process of fitting an IO-320 ...... still with the
battery on the firewall .... but with a wooden prop to help keep the
balance.
The battery is about 8" high , 6" wide & about 3" deep .... and cranks
over our high compression 0-235 very well
Hope this helps
Rick & Wendy Harper
541R
Australia
Sent: Tuesday, May 27, 2003 6:10 AM
far aft
wings
firewall
location.
builders.
Norm Wandke
