I have not been able to find a distributor for the Warner actuator you spoke
of.
Would you be able to locate the company name you purchased yours from?
Webb site would also be helpful, if available.
Guy
Sent: Tuesday, May 13, 2003 10:21 PM
Subject: Re: actuator
TheyGuy, I have one coming out of the states for 170 us by parcel post. Best
price here in Edmonton was 300 cdn plus shipping via ups, over 350 plus.
havecome in 12 & 24 volts are about 6 1/2 " long retracted and weigh 1.25 lbs
shuta 2" stroke (available in 2,4 & 6") and has builtin limiter switches that
rearoff and each end of stroke. Completely enclosed and have long life time of
cycles. They also have ones with potentometers (not spelled right) will
indicate their position on a meter. The one I saw in Bob,s plane was added
after completion. He mounted it parrell to the mixer bar and used another
bellcrank to keep the assembly under the window. I am not putting in a
madewindow so I will mount mine at 90* to the bar. Try running a search under
linear actuators on the internet. I'm at work right now but can get the
company name if you need it or can't find it on the internet. They were
rightby Warner Elec. but now distributed by another company. Name escapes me
now.
Steve W.
Guy L.-> Can you tell me more about the linear actuator?
-> Sounds interesting for my Rebel.
-> Thanks
Has anyone used those wonderful
ago.-> > linear actuators with 75 lbs working force/300 lbs static weighing a
-> wopping
-> > 1.25 pounds for flaps? Saw one in Bob DURANDS in Edmonton a while
-> Very> -> > nice.
-> > Steve W.
