I'm sure you will still need rivets the entire length... otherwise you're not
really tieing the pieces together that well even with the ribs and hinge
bolts. But this would really be a question for Brian at MAM.
On 5/23/2003 8:06 PM, MURPHY-REBEL@DCSOL.COM wrote to MIKE DAVIS:
3500I am just starting and I am getting ready to install the triplers I guess
that fit inside the horizontal stab rear spar. The question I have is the
fullmod book shows them getting rivited on a one inch pattern just to hold them
together. I think that was written when a shorter piece was used and not the
length triplers....... true/false? I just need to know if I need to use that
rivit pattern for the entire length of the spar? There are already alot of
rivits between the ribs and the hinge bolts. Thanks, Brad
