Oil shut off M14P
George Coy
Oil shut off M14P
Post by George Coy » Fri Feb 17, 2012 11:02 pm
Several people have asked about an oil tank shut off valve for the oil tank
on the M-14P engines. It is a really good idea and will help avoid hydro
lock. I believe Kimball enterprises offers a valve, but is currently out of
stock. We have used a fuel shut off valve from Speedway motors (402-323-3200
or WWW.speedwaymotors.com). They have a ball valve assembly with an AN-12
outlet. The inlet is unfortunately set up for one of their fuel filters. We
disassemble the valve assembly to avoid damage while welding and weld a
AN-12 fitting on the inlet side. It makes a really good setup.
George Coy SR154
George Coy
Oil shut off M14P
Well guys, I forgot to give you the part number for the valve. It is 546738
and is priced at $79.95.
George Coy
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of George
Coy
Sent: Monday, May 12, 2003 3:50 PM
Subject: Oil shut off M14P
George Coy SR154
