The header tank is 61/4 in wide, 81/2 inch deep(front to back) and 41/4 in
high. This holds about a gallon. The front fittings are bulkhead AN fittings
that I welded to the tank and simply drilled holes in the firewall and used
bulkhead nuts to secure the tank. I put some small ears on the bottom and
riveted it to the belly as well. It could be made wider and longer front to
back. I just folded up some aluminum on hand and welded it up and leak
checked it.
George
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com]On Behalf Of
rickhm@mindspring.com
Sent: Tuesday, April 29, 2003 12:43 PM
To:
murphy-rebel@dcsol.com
Subject: Re: RE: lycoming I0-540
George,
How big is your header tank (rough dimensions)? Where you describe you
placed it (if I understood) there isn't lots of room with rudder peddles and
all. In the reading that I have done they suggested a minimum of 2 gallons.
Rick Muller
SR70
-------Original Message-------
george@gesoco.com>
Sent: 04/28/03 04:24 PM
To:
Subject: RE: lycoming I0-540
Phil,
They are correct that a return line is not required. That said, on my
Io540-G1D5 instillation I am using a header tank and putting a 1/4 return
line from the throttle body inlet to the header tank. It will have a
restrictor on the line about 1/16 inch drill size. The header tank is then
vented back to the right main tank. The header tank is fed be the tow main
tanks and I located it under the floor on the right side right up t the
fire
wall. It also has a drain out the bottom of the airplane for the low point
in the system. The reason I did it is that it allows me to circulate cold
fuel on hot days during starts as well as a last chance for any air or
vapors to "escape" back to the tank. It is extra work, but I think it is
worth it. I basically copied a fuel system from a certified aircraft with
the same engine.
George Coy
mike.davis@dcsol.com]On Behalf Of Phil
McGrogan
Sent: Monday, April 28, 2003 8:54 AM
To:
Subject: lycoming I0-540
I am doing the fuel system in my SR3500 and would like to know if any
anyone knows the volume of the return flow from the fuel injector
(lycoming
part #77003). The engine is an IO-540 G1D5 with a bendix fuel injection
system. The reason I am looking for this info is to decide if I need to
run
a return line back to the tank, or if the flow is minimal, I can tee the
return upstream of the gasolator (with a check valve). Thanks in advance
for your time.
Phil
McGrogan
SR032QB
<a target=_blank
href="
http://www.dcsol.com:81/public/code/htm ... ://www.dcs
ol.com:81/public/code/html-subscribe.wcx</a>
Archives located at <a target=_blank
href="
http://rebel:builder@www.dcsol.com:81/d ... bel:builde
r@www.dcsol.com:81/default.htm</a>
To contact the list admin, e-mail
<a target=_blank
href="
href="
Archives located at
Archives located at
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
