Received: from fwd14.btx.dtag.de (fwd14.btx.dtag.de [194.25.2.174])
by mailout10.btx.dtag.de with smtp
id 10W4u3-0002qa-00; Sat, 10 Apr 1999 23:02:59 +0200
Received: (068612707-0001(btxid)@[62.157.55.169])
by fwd14.btx.dtag.de
id <m10W4tv-0003QdC>; Sat, 10 Apr 1999 23:02:51 +0200
Message-Id: <m10W4tv-0003QdC@fwd14.btx.dtag.de>
Date: Sat, 10 Apr 1999 23:02:51 +0200
Subject: Looking for Propeller
X-Mailer: T-Online eMail 2.2
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 8BIT
X-Sender: 068612707-0001@t-online.de
From: Johannes.Laubenthal@t-online.de (Johannes Laubenthal)
Hi Rebel Group!
I am looking for a propeller for two rebels . Here in Germany noise is a
serious problem to get your flight permission by the German LBA (Luftfahrt
Bundesamt ).Many microlights use Warp props here.
Questions:
1. Any information on 3 or 4 blade Warp Prop for 100 HP Rotax 912S
2. Any information on 3 or 4 blade Warp Prop for 160 HP O-320
Diameter ? Pitch ? Climb rate ? Cruising Speed / RPM ?
Phone number Warp ??
Regards Johannes
Received: from [137.186.224.40] (helo=ms01-40.tor.istar.ca)
by mail4.toronto.istar.net with smtp (Exim 1.92 #2)
for murphy-rebel@dcsol.com
id 10YLUA-00059T-00; Fri, 16 Apr 1999 23:09:38 -0400
Mime-Version: 1.0
To: (Murphy Rebel)
Subject: Re: Looking for Propeller
Message-Id:
Date: Fri, 16 Apr 1999 23:09:38 -0400
For the 912-S, you could probably still use a GSC wood prop, with the
epoxy leading edge. The 2 blades are better than the 3 blades, if you can
get away with it from a noise perspective (should be OK). 72 inch dia., "M"
blades, ground adjustable, (or in-flight adjustable, for a LOT more money
If you do go with the Warp Drive, consider the same prop as the O-320's,
in a 3 blade, but set at a finer pitch. (GSC's are a lot cheaper !)
For the O-320's, the consensus seems to be overwhelmingly in favour
of the Warp Drive 3 blade, 72 inch dia., with 17" of nickel leading edge,
and SQUARE tips (NOT tapered !). Usually set in the 12 1/2 to 13 1/2
degree range....
A few have been talked into the 4 blades for higher powered engines
- NOT a good idea !! Too much drag on descent (can't get below 2,500 rpm
and a lot of load on the engine - hard to get the right pitch setting...
Stay with the 3 blade Warp Drive - most folks here just LOVE them !!
W-D have proven to be a VERY good company to deal with - several have
exchanged their 4 blades for 3 blades, at VERY reasonable cost, even
after a season of flying !!
Mime-Version: 1.0
To: (Murphy Rebel)
Message-Id:
degree range....
Hi Rebel Group!
Questions:
Regards Johannes
Received: from d12relay01.de.ibm.com (d12relay01.de.ibm.com [9.165.215.22])
by d12lmsgate.de.ibm.com (1.0.0) with ESMTP id NAA21160
for <murphy-rebel@dcsol.com>; Wed, 28 Apr 1999 13:26:06 +0200
Received: from d12mta05.de.ibm.com (d12mta05_cs0 [9.165.222.239])
by d12relay01.de.ibm.com (8.8.7m1/NCO v1. with SMTP id LAA38998
for <murphy-rebel%dcsol.com@Internet.ae.ibm.com>; Wed, 28 Apr 1999 11:45:05
+0200
Received: by d12mta05.de.ibm.com(Lotus SMTP MTA Internal build v4.6.2
(651.2 6-10-1998)) id C1256761.00359047 ; Wed, 28 Apr 1999 11:45:03 +0200
X-Lotus-FromDomain: IBMDE
Message-ID: <C1256761.00358F38.00@d12mta05.de.ibm.com>
Date: Wed, 28 Apr 1999 11:44:57 +0200
Mime-Version: 1.0
Content-type: text/plain; charset=us-ascii
Content-Disposition: inline
Bob,
I'm one of those who got talked into a 4-blade Warp prop, as you said.
The arguments were:
- less HP per blade (apparently there is a chance of damaging the blades
with a 3-blade prop on a 160hp engine)
- less noise (68" vs. 72" diameter makes a big difference)
In Germany many people fly happily with 4 blades even 5 and 6 blade props
are common, all because of noise.
The German prop manufacturers insist that there is no big performance
penalty with multi-blade props, if any.
I just don't like to spend the money for a German MT prop (which you find
on the Extras).
Bob, can you give me the names and addresses of the Rebel fellows who
exchanged their 4 blade against a 3 blade Warp.
I'd like to understand the implications. Thanks.
Stefan Pappe, Heidelberg, Germany, Rebel 156
Bob Patterson <bob.patterson@canrem.com> on 17.04.99 05:09:38
Please respond to murphy-rebel@dcsol.com (Murphy Rebel)
To: murphy-rebel@dcsol.com (Murphy Rebel)
cc: (bcc: Stefan Pappe/Germany/IBM)
degree range....
+0200
Mime-Version: 1.0
Bob,
The arguments were:
on the Extras).
degree range....
Hi Rebel Group!
Questions:
Regards Johannes
Received: from nidlink.com (pm5-40.nidlink.com [216.18.141.47])
by enaila.nidlink.com (8.9.0/8.9.0) with ESMTP id HAA20092
for <murphy-rebel@dcsol.com>; Wed, 28 Apr 1999 07:48:58 -0700 (PDT)
Message-ID: <372721C7.EDC9C383@nidlink.com>
Date: Wed, 28 Apr 1999 07:57:11 -0700
X-Mailer: Mozilla 4.5 [en] (Win95; I)
X-Accept-Language: en
MIME-Version: 1.0
References: <C1256761.00358F38.00@d12mta05.de.ibm.com>
Content-Type: text/plain; charset=x-user-defined
PAPPE@de.ibm.com wrote:
satisfied. I will probably try the 3 blade this year to see the
difference if any.
Dave Bangle http://www.subielyc.com/
MIME-Version: 1.0
"M"Bob,
The arguments were:
on the Extras).
I have run a 4 blade on my Rebel for the last year and have been veryblades, ground adjustable, (or in-flight adjustable, for a LOT more money
degree range....
after a season of flying !!> >
difference if any.
