Flaps angles for Elite
Post by Walter Klatt » Sat Feb 18, 2012 1:49 am
This fellow is building an Elite and has asked what is
the perfect flap setting for taking off from the water
on floats. He is setting his up with separate flap and
aileron droop controls. I'm not sure if the Rebel is
the same as the Elite, but with mine I usually use 1/2
flaps for take-off. However, I have never done the full
tests with different weights and power settings to
absolutely confirm what is the best setting. So I said
I would ask you guys to see if anyone has figured this
out for their Rebel.
From: DENNIS FINLEY [mailto:croydonmachining@telus.net]
Sent: Wednesday, February 26, 2003 7:38 AM
To: Walter Klatt
Subject:
walter could you ask the rebel guys what is the prefect
flap angle for
float take off,based at the flat at the bottom of the
wing.I've been
working late hours and haven't been able to call.i need
to no the prefect
angles to calculate my cylinder stroke.
thanks
dennis
Post by Bob Patterson » Sat Feb 18, 2012 1:49 am
Hi Walter !
I dunno what the 'perfect' flap setting is - I always
used full flap for takeoff, on wheels and floats !
Of course, I dropped a notch for best climb, after
about 50 feet or so, so your using 2 notches all the way
would be less fiddly than my way.
-----------------------------orig.-------------------------------
To: Walter Klatt
Subject:
flap angle for
wing.I've been
to no the prefect
thanks
dennis
Thanks Bob, I couldn't give him anything concrete
either. My float take-off runs depend more on how good
I am with hitting the sweet spot, wind and weight than
my flap setting, so I wasn't a lot of help. When I get
chance sometime, I still want to do some experimenting
with partial power and loaded up, and then maybe I can
determine which flap setting is best.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Friday, February 28, 2003 10:24 AM
Subject: Re: FW: Flaps angles for Elite
Hi Walter !
best climb, after
all the way
asked what is
from the water
separate flap and
usually use 1/2
done the full
figured this
To: Walter Klatt
Subject:
prefect
flap angle for
wing.I've been
need
to no the prefect
thanks
dennis
Archives located at
Archives located at
