Re Split flaps question
Ian Donaldson
Post by Ian Donaldson » Fri Feb 17, 2012 10:43 pm
G'day
If someone wishes to see for himself, if the split flaps work
satisfactorily, or not, I have the complete factory conversion kit that I
did not use.
The only reason that I did not put split flaps on my Rebel was because MAM
did not send the instructions with the kit. When I finally got things sorted
I could not be bothered and went with the standard aileron set up.
This kit would go cheap if it went to a good home!
Regards
Ian Donaldson
