Received: from LOCALNAME (gnd223.nf.sympatico.ca [142.163.8.87])
by MAIL2.NFLD.NET (8.8.6 (PHNE_14041)/8.8.6) with SMTP id VAA26504
for <murphy-rebel@dcsol.com>; Fri, 12 Feb 1999 21:41:52 -0330 (NST)
Message-ID: <36C520D1.4D46@nf.sympatico.ca>
Date: Fri, 12 Feb 1999 22:50:57 -0800
Organization: Smith Services
X-Mailer: Mozilla 2.02E-SYMPA (Win16; I)
MIME-Version: 1.0
Subject: Elevator Control
References: <199902102212.LAA19561@host02.net.voyager.co.nz>
Hi Group,
So glad to finally be a member. I'm at the controls installation stage of
my fuselage now and just today I completed running the elevator cables.
My elevator control is very tight, too tight. I beleive the problem is
in the delrin bearing blocks. I did have to sand slightly before
assembly but I didn't want to make the controls too sloppy. Will this
tightness go away with use or should I keep sanding out the bearings?
How about lubricant? Yeah, I know the manual says not too, but I still
thought I'd ask. Thanks. Clay
Elevator Control
Mike Davis
Elevator Control
Received: from ms01-486.tor.istar.ca ([137.186.225.232])
by mail1.toronto.istar.net with smtp (Exim 2.02 #1)
id 10Bn9J-0006ce-00
for murphy-rebel@dcsol.com; Sat, 13 Feb 1999 17:02:53 -0500
Mime-Version: 1.0
Subject: Re: Elevator Control
Message-Id: <E10Bn9J-0006ce-00@mail1.toronto.istar.net>
Date: Sat, 13 Feb 1999 17:02:53 -0500
Welcome aboard, Clay !!
This is a very common problem - the solution is: just keep on sanding !
It seems the Delrin is definitely too tight, as delivered. Almost everyone
has had this problem...
And the manual is right - NO lubricant (it can shrink the Delrin
later !)
While you're setting everything up, this is a good time to remind
everyone to be sure to adjust the elevator travel so you get AT LEAST
27 degrees of UP elevator (some have as much as 30 degrees!) This is
more than the manual, but is necessary for a decent flare on landing,
especially with heavier engines ! Don't worry if this reduces the
DOWN travel - even 20 degrees is lots there..
....bobp
--------------------------------orig.-------------------------------
id 10Bn9J-0006ce-00
Mime-Version: 1.0
later !)
....bobp
Hi Group,
Doug Martin
Elevator Control
As per AC 43.13-1B/2A Par. 7-166 " Tunbuckle Installation" You are allowed
3 (Three) threads showing out side of the barrel or 4 threads inside the
baarrel. Cable strech will vary with the type of cable (galvanized, carbon
steel, stainless steel) and of course temprature. Check out Chapter 7
section 7 and 8. in the above Advisory Circular, at your local airport shop.
Doug in Reno
At 02:50 PM 2/6/2000 -0330, you wrote:
greyghost@powernet.net
Doug in Reno
Doug MartinI'm about to make a second cable (I didn't have necessary 27 degrees up
defection on the first) for my elevator control. Can someone tell me
how many threads can be showing on the turnbuckle? Also, should I allow
for some later tightening adjustment for cable stretching?
Thanks, Clay
Elevator Control
Your following message has been delivered to the 148 members of
the list murphy-rebel@dcsol.com at 15:24:14 on 6 Feb 2000.
Clay,
No more than 3 threads are allowed to show on either threaded portion of a
turnbuckle! Also, like all An hardware, do not lubricate to make easier to
adjust.
The cables will stretch slightly, but if you start out with the three
threads showing, it leaves you lots of adjustment for snugging up later!
Sounds like you are getting close!!!!
Date: Sunday, February 06, 2000 1:56 PM
Clay,
adjust.
*----------------------------------------------------*I'm about to make a second cable (I didn't have necessary 27 degrees up
Thanks, Clay
Clay Smith
Elevator Control
Thanks, Clay
Thanks, Clay
