Digest for 7 Feb 1999
Mike Davis
Post by Mike Davis » Fri Feb 17, 2012 5:18 pm
Received: from albedo.net (ppp147.albedo.net [206.51.22.166])
by juliet.albedo.net (8.9.0/8.9.0) with ESMTP id JAA15585
for <murphy-rebel@dcsol.com>; Tue, 9 Feb 1999 09:13:57 -0500
Message-ID: <36C0418A.4AFA247F@albedo.net>
Date: Tue, 09 Feb 1999 09:09:14 -0500
MIME-Version: 1.0
Subject: Re: Digest for 7 Feb 1999
References: <cc158da.36bfa160@aol.com>
Paul and Peg
Personally if you have the .020 originals I would (and did) upgrade to .032.
If
you have the .025 ones installed, I would leave them there. Believe .025 is
adequate and MAM went to .032 mostly because they were already stocking that
thickness as a Elite part. MAM might confirm this if you ask them. Also
believe
only the bottom wraps are upgraded. Just my opinion of course as I haven't
flown
mine yet.... There was a long thread on this about last Sept.
I also like Bobp's suggestion to upgrade the panel below the door sill
(immediately behind the cage) to .025 or .032.
PMi4218393@aol.com wrote: <heavilly snipped>
are most of the
folks putting the larger engines, i.e., 0-320's & Subaru's doing the .032
corner wraps? Any other mods on the front?
Paul & Peg
Mike Davis
Received: from the-benson-s (209-122-204-45.s553.tnt3.lnh.md.dialup.rcn.com
[209.122.204.45])
by smtp2.erols.com (8.8.8/8.8.5) with SMTP id KAA09043
for <murphy-rebel@dcsol.com>; Tue, 9 Feb 1999 10:42:27 -0500 (EST)
Message-ID: <000601be5442$7a4b9120$2dcc7ad1@the-benson-s>
Date: Tue, 9 Feb 1999 10:39:16 -0500
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3155.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
Hi Paul:
Those Rebel flyers that are on floats or use unimproved strips are
recommending that you upgrade to the .032 front corner wraps. I have. The
archives at www.dcsol.com/lists/mr98/#end are a good source for background
info on additional front end mods.
Can you put the profile on the net?
I talked to Curt at Oshkosh about the locking mechanism for their swing up
door. He said tha he would try to get something on paper. I guess I'll
have to ask him how he's doing.
lonben@erols.com 171R
Date: Monday, February 08, 1999 10:10 PM
I'd have to concur with Bob P's comments on Met-All. We used to polish
DC-3's, 6's and Convairs in the Marines with the stuff. Lasted the longest
any of the stuff we tried. That's why everything on our Rebel will be
painted.
Lonnie: The "gear fix" is where I'm at right now...along with doing
something
along the line of Curt & Bill's mod for the swing-up doors. Are most of
Brian: We got a 'profile' to work on the paint scheme from Murphy. I can
send
it.
Those folks on floats...are the Murphy recommended positions of the fuel
sumps
adequate? Not being a float pilot yet is there a better position on the
fuselage for the Transponder antenna then under the cabin belly...outside
of a
top mounted antenna?
Paul & Peg
S/N 374
Mike Davis
Received: from brady (207-172-77-60.s60.as1.lee.erols.com [207.172.77.60])
by smtp3.erols.com (8.8.8/8.8.5) with SMTP id CAA02303
for <murphy-rebel@dcsol.com>; Wed, 10 Feb 1999 02:55:12 -0500 (EST)
Message-Id: <199902100755.CAA02303@smtp3.erols.com>
X-Sender: mlidd@pop.erols.com
X-Mailer: QUALCOMM Windows Eudora Pro Version 4.0
Date: Wed, 10 Feb 1999 02:50:46 -0500
In-Reply-To: <000601be5442$7a4b9120$2dcc7ad1@the-benson-s>
Mime-Version: 1.0
Anyone know where zips of the archives is located?
At 10:39 AM 2/9/99 -0500, you wrote:
Hi Paul:
longest
painted.
something
send
it.
sumps
of a
Paul & Peg
S/N 374
Mike Davis
Received: from aws1.bp.nrl.navy.mil [132.250.13.17]
(HELO localhost)
by alpha1.tf.bp.nrl.navy.mil (AltaVista Mail V2.0J/2.0J BL25J listener)
id 0000_0055_36c1_7a11_cd81;
Wed, 10 Feb 1999 07:22:41 -0500
Received: by bpvax.tf.bp.nrl.navy.mil (UCX V4.2-21, OpenVMS V7.1 VAX);
Wed, 10 Feb 1999 12:23:26 -1233
Message-ID: <007e01be54f0$25b47420$b300a8c0@tf.bp.nrl.navy.mil>
Date: Wed, 10 Feb 1999 07:23:19 -0500
MIME-Version: 1.0
charset="Windows-1252"
X-Priority: 3
X-Mailer: Microsoft Outlook Express 5.00.0810.800
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.0810.800
There are not any zips of the archives available at this time. If this is
something folks would like I can look into setting this up. The archives
are currently all in HTML format, so if I made ZIP files available, I'd
probably just zip up the whole directory, then you could view it with your
browser.
Sent: Wednesday, February 10, 1999 2:50 AM
