"CPDG" plastic washers
mbanus
Post by mbanus » Thu Mar 05, 2020 5:14 pm
I have some approximately 1/2" thin plastic washers with a 3/16 hole. Can't find where they go. What are they for? Chapter?
schaumr
Re: "CPDG" plastic washers
Post by schaumr » Fri Mar 06, 2020 6:56 am
There's at least one that goes between the attach brackets when you install the rudder on the vertical stab.
Can't recall now whether all the empennage hinges need them.
Also, they are called-for when installing the front attach bracket on each horizontal stab (where it connects to the fuselage).
That attachment sometimes needs shimming.
Rob Schaum
Rebel 786 - Flying Since 2022
Connecticut
http://mykitlog.com/schaumr
mbanus
Post by mbanus » Fri Mar 06, 2020 4:20 pm
Thanks, someone told me that they were to be used to hold fabric on Ailerons and Flaps, but nothing in the build manual mentioned that.
Mark Banus
676R EAA 534 Youth Group Project
schaumr
Post by schaumr » Sat Mar 07, 2020 5:29 pm
the fabric is held on with special aluminum washers and rivets....no plastic washers
Rob Schaum
Connecticut
Flying Indian
Post by Flying Indian » Wed Mar 11, 2020 6:25 pm
My washers are marked DRAIN GROMMETS ! you put them on trailing edges of ailerons for sea planes ?????? I guess you can use them for shim / wear plates ???
