I have an Elite that I need to move. Looking for tips regarding wing, empennage removal and minimum size trailer required to move fuselage
Thank you
Transport fuselage
Washington Rebel
Re: Transport fuselage
I moved mine 3 times now on a 8 x 16 trailer
had to remove one side of the tail because it was over 9 feet wide
used 2 2x12 boards to support the tires
dont make the straps on the airframe too tight or something will bend
I used straps going to opposite sides of the trailer so if it moved one way the other strap would tighten
drove 45 mph no problems
Tom
Rebel 831R
Flying as of May 2016
Rebel 831R
Roger that Tom, thanks. My problem is this a/c has a nose wheel and distance between main gear, outside to outside is 8'. Hard to find an 8'wide trailer, but lots of 7'. I have thought of using2x8's to support the main gear and then tie the tail down to the deck
Can you tell me if I can take the vert stab and rudder off before the horiz stab/ and elev off
Cheers, H
Cheers, H
Washington Rebel
Yep you got me mine was 7 ft wide also
Thats why i screwed down the 2 x 12 and strapped the tires to it
Not sure about the tail as the rebel is different that the elite
Tom
Rebel 831R
Rebel 831R
