Hi all,
I see that MAM recommend automatic transmission fluid for brake fluid.
Has anyone had problems with this?
Is there a particular auto trans fluid to use? Or is Dexron 3 the go?
Thanks for all replies.
Cheers Mike 818R in OZ........only two more electrical things to connect.....I hope.
Brake Fluid, three questions
Re: Brake Fluid, three questions
mikeh wrote:Hi all,
I have been using Dexron 3 synthetic with no problems. After a couple of years the fluid exposed to the sun in the clear lines becomes clear. I used Wayne's suggestion of filling lines from the bottom up with an oil squirt can, and that worked great for getting air out of the line.
Allen H
Definitely ! Use ATF ... only problems have occurred when people used 'aircraft' or automotive
brake fluid - it ATE THE RUBBER in the cylinders !!
Any good ATF will do, Deltron/Dextron ?? is fine !
....bobp
Thanks Alan and Bob,
Your input is much appreciated.
Cheers Mike
Cheers Mike
