[rebel-builders] engine storage
Hi keith
So is it 2 or 3, I suspect its number 2
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Keith Leitch
Sent: February 2, 2009 6:35 AM
Subject: Re: [rebel-builders] engine storage
Mike,
Mike,
I'll walk over to the hangar after lunch. I got busy yesterday trying to prep some skis for painting and forgot. :(
-22 this morning so not in a big hurry to get outside. Isn't Northern Minnesota wonderful in the winter? LOL
Yah sure, you bet-cha !!
Cheers, Bob 612e
Leitch
Sent: Tuesday, February 03, 2009 8:28 AM
Subject: RE: [rebel-builders] engine storage
Cheers, Bob 612e
Leitch
Hi all,
Just my views on engine storage, learned some the hard way and some from
finally learning to listen. Ok, some of the time:)
The best thing to do is not to store. Fly it every couple of weeks.
Store it in a climate controlled hanger. I still dream about having one of
those.
If you gotta store, remember the lycoming cam sits way up near the top of
the engine. No long term protection from corrosion. The 2 best and well
respected engine o'haulers in the area both are firm believers in the use of STP
if you don't fly often. Less than 75 hrs a year.They say you can tell the
difference the moment they crack the case.
If you use it, the cam and lifters are in great shape. If not, they get sent
for O'haul.
As for storage oils, part of the design is for cling ability. It stays on
the cam longer
What they say not to do?
Once it has been pickled do not pull the prop thru every now and then. You
just wipe the oil off the cylinders. Don't use an engine heater that is put
on a timer and cycles every so often. You just make a big water manufacturing
system.
The best thing to do? Fill it full of oil. I'm talking about 3 gals worth.
Yes it fills the intakes, weeps past the rings and fills the cylinder heads,
drips out the carb, and gets into the exhaust system. Makes a good way to
find that annoying leak too. When its time to fly again, pull the plugs and pull
the prop thru, change the oil to the normal oil you use and the correct
amount, fire it up and kill a few mosquitoes from the oil in the exhaust. No
sticky valves and a cam that is the same way you put it away.
The only other thing I have heard , with no experience, is a whole engine
dehydrator.
IMHO
Curt Martin
N97MR
**************Great Deals on Dell Laptops. Starting at $499.
(http://pr.atwola.com/promoclk/100000075 ... oubleclick.
net/clk;211531132;33070124;e)
those.
for O'haul.
the cam longer
system.
dehydrator.
IMHO
Curt Martin
N97MR
Curt,
That is what I did to my Champ which has an O-235. I filled it to the brim with oil when stored for the winter. It was the Cont. O-300 in my 172 that I sprayed with LPS-3. SOrta hard for me to fly every couple of weeks with the crappy weather we have been having here in MN.
Keith
Date: Wednesday, February 4, 2009, 6:34 PM
Hi all,
those.
of STP
for O'haul.
the cam longer
put
system.
worth.
pull
dehydrator.
IMHO
Curt Martin
N97MR
Keith
Hi all,
those.
of STP
for O'haul.
the cam longer
put
system.
worth.
pull
dehydrator.
IMHO
Curt Martin
N97MR
How about turning the engine upside down every so often to let the oil
contact the cam? This would be for an engine stored in your garage or hangar
for an extended period of time.
Leitch
Sent: February 4, 2009 4:49 PM
Curt,
Keith
Hi all,
those.
of STP
sent
for O'haul.
the cam longer
put
manufacturing
system.
worth.
heads,
pull
No
dehydrator.
IMHO
Curt Martin
N97MR
(http://pr.atwola.com/promoclk/100000075 ... ?redir=htt
p://ad.doubleclick.
Leitch
Curt,
Keith
Hi all,
those.
of STP
sent
for O'haul.
the cam longer
put
manufacturing
system.
worth.
heads,
pull
No
dehydrator.
IMHO
Curt Martin
N97MR
p://ad.doubleclick.
What type of oil did you use to fill the engine with ??
Got lps 2 and 3 to spray already, see polyfibre has an oil for engine
storage but no in stock anywhere here
thanks
Rebflyer@aol.com
Sent: February 4, 2009 7:34 PM
Hi all,
from
one of
those.
top of
use of STP
sent
for O'haul.
on
the cam longer
You
put
manufacturing
system.
worth.
heads,
and pull
exhaust. No
engine
dehydrator.
IMHO
Curt Martin
N97MR
(http://pr.atwola.com/promoclk/100000075 ... /aol?redir
=http://ad.doubleclick.
thanks
Rebflyer@aol.com
Hi all,
from
one of
those.
top of
use of STP
sent
for O'haul.
on
the cam longer
You
put
manufacturing
system.
worth.
heads,
and pull
exhaust. No
engine
dehydrator.
IMHO
Curt Martin
N97MR
At 05:52 PM 04/02/2009 -0800, you wrote:
stand that has a rotation feature and mounted his rebuilt 0-320 on it. He
goes out to the shop and gives it a full turn every week or so. It's going
to need a lot of turns he's building a Falco and last time I had the nerve
to ask he was still working on the rudder.
LOL I have a neighbour that does that He bought a cheap automotive engineHow about turning the engine upside down every so often to let the oil
At 10:13 AM 05/02/2009 -0500, you wrote:
but if you're going to fill the engine right up I'd think anything would
work.
Shell makes a storage oil for aircraft engines that I've used in the pastWhat type of oil did you use to fill the engine with ??
thanks
work.
If you are filling the engine up with oil, really any good product will do.
Shell does make a storage specific oil, and I think Phillips does too, but
they can both be run in the engine for a short time. I just drain the storage
oil I use and save it. I do not run the engine on it.
Curt N97MR
Curt N97MR
