Ben
Some people put rivets in them some put bolts, I put rivets, it holds
the 2 pieces together little better
bransom@dcsol.com
Sent: January 26, 2009 11:41 AM
Subject: [rebel-builders] rear spar attach bracket
Hi all,
MAM has a couple extra holes drilled in the rear spar attach bracket.
Are
these just extra rivet holes or are they for some other purpose?
Picture for reference:
http://mae.ucdavis.edu/ransom/Murphy/mi ... Attach.jpg
-Ben, 496R
Hi Ben
Mine don't have those holes. May be it because mine is a later S/N 802R
Charlie
Sent: Monday, January 26, 2009 10:41 AM
Charlie
Hi all,
MAM has a couple extra holes drilled in the rear spar attach bracket. Are
-Ben, 496R
I meant to say that MAM instructions are to drill the two additional holes.
Mine (496R) doesn't have the holes predrilled either, which just seems a
little odd since the rest of the holes are already there. Guess I'll just
go ahead and drill them for now.
-Ben
-Ben
Hi Ben
Charlie
Hi all,
-Ben, 496R
HI ben,
I thought you were done with your wings. What gives? Craig in Alaska
bransom@dcsol.com
Sent: Monday, January 26, 2009 4:00 PM
Subject: Re: [rebel-builders] rear spar attach bracket
-Ben
bransom@dcsol.com
-Ben
AreHi Ben
Charlie
Hi all,
-Ben, 496R
Hey Craig,
Yep, done with the wings --- this was in ref to the mating brackets on the
fuselage.
-Ben
fuselage.
-Ben
HI ben,
bransom@dcsol.com
-Ben
AreHi Ben
Charlie
Hi all,
MAM has a couple extra holes drilled in the rear spar attach bracket.these just extra rivet holes or are they for some other purpose?
-Ben, 496R
