Unless the builder is a glutton for punishment, and really wants to install
~ 50-60 more traditional nutplates with three holes and two countersunk
rivets each... this is yet another excellent application for Click Bond
nutplates. Drill _one_ hole, slather the epoxy adhesive on the back of the
nutplate, pull the self-centering, self-tensioning silicone nipple through
the hole, wait 24 hrs., and you're done.
Ron
http://n254mr.com
If true, you could use fewer screws, save weight and time installing nut
plates. You should use nutplates as everyone has mentioned, the panel is
structural.
