[rebel-builders] Extra hole Fus-2
gleeso
Post by gleeso » Sun Feb 19, 2012 8:02 pm
G'Day Charlie, Mine are the same, I just assumed they were tooling holes
and ignored them.
FWIW
John
Rebel 804 Down Under
Charlie Eubanks wrote:
[quote]Hello All
I have started on the forward fuselage assembly and am presently
constructing the Cage Assembly 12.9. I will be using the standard bungee
gear with die springs so in the interest of saving weight, I have decided to
cut one bottom carry through (fus-5) in two pieces and am presently drilling
and clecoing the fus-2s gussets to the fus-5 and the vertical fus-4s. All
four of my fus-2 gussets have an extra
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:02 pm
It's a beautiful hole to run fuel lines or a conduit for wires thru !
Sent: Saturday, November 08, 2008 7:00 PM
Subject: [rebel-builders] Extra hole Fus-2
[quote]Hello All
drilling
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 8:02 pm
My caryy throughs where cut I half when I got my kit which was partially done, it proved to be a real problem with many unforseen issues to resolve
You need to keep (this is a big issue I found) in mind your spacing for the control tube mounting supports will no longer be correct for mounting onto the carry through, so I used a 1/8 plate riveted over the tubes and then attached the mounting tubes to the plate, this resolved the mounting problem caused by the small carry through flange width and any clashs with the webs of the carry throughs, if you put plates over top like I did don't forget to use cs rivets so plates sit flush
Also where bolts go through the new carry throughs I put aluminum blocks between carry throughs so when torqueing the bolts the carry through is not crushed or stretched out of shape
Regards
Mike#007
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Charlie Eubanks
Sent: November 8, 2008 7:00 PM
Hello All
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 8:02 pm
John you may be right but wouldn't you think that a
It used to be a 1/4" or so tooling hole back in the early '90's and we were
all drilling it out to 1/2" anyhow. Maybe that's how it became a predrilled
1/2" hole from the factory!
Putting a 1/2" hole thru the upright tubes appears to have no effect on
structural strength there. I've rebuilt some pretty nasty wrecks... with the
uprights looking like a drawn archery bow.. and still no damage to the
Fus-2's or the upright tube in their immediate area.
Sent: Sunday, November 09, 2008 1:55 PM
Subject: Re: [rebel-builders] Extra hole Fus-2
[quote]John you may be right but wouldn't you think that a
Charlie Eubanks
Thanks Wayne
That makes more since now. Sure would be nice if they would put it on the
drawing.
Charlie
Sent: Sunday, November 09, 2008 1:03 PM
[quote]It used to be a 1/4" or so tooling hole back in the early '90's and we
were
predrilled
