[rebel-builders] Main gear carry though
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 7:56 pm
What engine are you going with Charlie? (I think you're going 912 - which is
100+ pounds less - hanging out front - which I'm thankful for every time I
bounce the Rebel onto the strip)
The carry throughs are cut in 1/2 on my plane - 821 empty weight with the
912 - 100HP.and Scott 3200. The only thing that happens -IMHO - is that when
you mount the control column - you need to put a plate under it because the
control column mounting brackets only catch 1/2 of the carry through and not
both sides. (the floor only isn't enough to support the other side of the
bracket)
This has not been a problem and I did end up moving the control columns rear
word by - I think an 1"(I can't remember - I just know I wrestled with the
decision) - again - no issues for me. It actually gave me more stick
clearance from the panel.
Jim R333
On 10/23/2008 4:57 PM, "Charlie Eubanks" <charlie@troyairpark.com> wrote:
Hello Builders
I am at that point where I have to decide if I should use the full tube
carry through (Fus. - 5) or the half tube method to build the main gear
carry through. My first though is to save that 4.2 Lbs because it is my
intent to register my Rebel at 1320 Lbs and that's quite a weight savings.
On the other hand, how critical is the extra strength I would be giving up?
I would appreciate the thoughts and opinions of those of you who have
already made that choice.
Charlie E. 802R
Post by Drew Dalgleish » Sun Feb 19, 2012 7:56 pm
At 03:57 PM 10/23/2008 -0500, you wrote:
Hello Builders
Charlie E. 802R
IMO you won't be giving up any strength because the rivets holding the
carrythrough together aren't as strong as half an FUS 5. I think the only
reason not to cut it is if using the spring gear.
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 7:56 pm
Hi all
Came in from the shop minutes ago.I was going to ask the list about
weather
or not to split the FUS 5.Lo and behold someone was asking the same
question.
I am using an 0-320 should I be leaving them square?
Jason
817R
Hello Builders
tube
gear
is my
savings.
giving up?
Charlie E. 802R
only
bransom
Post by bransom » Sun Feb 19, 2012 7:56 pm
Unless I've badly missed something, MAM is clear on Fus-5, 4, etc
construction, and splitting Fus-5 has only to do with whether one is
installing spring or conventional (bungee or die-spring) gear. I think Bob
mentioned that most are no longer bothering to split Fus-5, for time
savings or lack of band saw, whatever, but not for structural reasons. I
heard this after I split mine, sold the extra one, and I'm still aiming
toward an 0-320. There's even a special small chapter devoted to 0320
planning, and it has nothing to do with Fus-5.
One other note on Fus-5 is just the reminder that if you are splitting, and
using conventional gear, and option for float installation, to use a
floating nut plate (5/16") for the gear wishbone bolts (Fig 12.9.9).
-Ben
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 7:56 pm
Jim, Drew & Ben
Thanks to all who re-plied to my gear carry through questions. Because I am
certifying at 1320 Lbs. and installing the bungee/die spring gear I think I
will split the tube and save the 4.2 Lbs. Good to hear I also will not be
sacrificing any structural strength in the gear mount.
Charlie E. 802R
Sent: Thursday, October 23, 2008 3:57 PM
Subject: [rebel-builders] Main gear carry though
Hello Builders
up?
Charlie E. 802R
At 10:19 PM 10/23/2008 -0400, you wrote:
Hi all
weather
question.
Jason
817R
Hi Jason I'm using an 0-320 as well. I've had no problems from splitting my
FUS 5 and expect I never will.
Rebecca Brownell
Roger that Drew ,
thanks
Jason
Hi all
weather
question.
Jason
817R
splitting my
