electrical connectors
Jones, Mike
Post by Jones, Mike » Fri Feb 17, 2012 5:57 pm
Hi all
Another source for electrical connectors is McMaster-carr, web link is
http://www.mcmaster.com/
they have online catalogue of thousands of other things as well. for
electrical connectors search under nano connectors
Mike#007
EOM
NOTICE - This message is the property of HATCH. It may also be confidential
and/or privileged. If you are not the intended recipient of this message
you are hereby notified that you must not disseminate, copy or take any
action with respect to it. If you have received this message in error
please notify HATCH immediately via mailto:MailAdmin@hatch.ca.
Electrical Connectors
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:08 pm
Got the following link from hanging out on Supercubs.org. Looks like a place
I could have used for years!! ;o)
http://www.terminaltown.com/
Rickhm at home
Post by Rickhm at home » Fri Feb 17, 2012 11:08 pm
Timing is everything! Looks great. For those putting the battery in the tail cone, what gauge of wire are people running #2 or #4?
Rick Muller
SR70
Sent: Saturday, May 24, 2003 5:09 PM
Subject: Electrical Connectors
*** File "WINMAIL.DAT" has been uudecoded and attached to this message.
Steve Halvorsen
Post by Steve Halvorsen » Fri Feb 17, 2012 11:08 pm
Anyone that has access to ordering from McMaster Carr would save a LOT of
Prices are about 50% to 70% less for the same thing as listed on
terminaltown and the SAME
manufacture. Prices are about $5.00 (US) for ring terminals (red) 100 to
the box, ect.
Just my 2 cents. Most terminals from McMaster are made by Molex.
Steve H.
Moose 213
Rickhm at home
Sent: Sunday, May 25, 2003 9:34 AM
Subject: RE: Electrical Connectors
Rick Muller
SR70
T
Good to know! I just poked my "eyes" into the site quickly and really liked
the ground solder units that you just bare a small spot on the shielded wire
and slip the connector over and then heat it with a heat gun/torch. Melts
the solder, shrinks the tube for a moisture proof seal and gives you a pig
tail for grounding, instead of going through the nonsense of combing out the
braid to get a terminal on it!
Sent: Sunday, May 25, 2003 3:14 PM
the box, ect.
Steve H.
Moose 213
Rickhm at home
Rick Muller
SR70
place
T
Legeorgen
Post by Legeorgen » Fri Feb 17, 2012 11:08 pm
Rick,
I used a #4 welding cable for an 0320 Rebel and it worked well all last
winter.
Bruce 357R
Steve Halvorsen
Rick:
I replaced my ALU. cables on my ARROW with a kit and it had #0 copper cable
with it.
Had slow starter problem. My battery is located in the tail.
Some of the kits for Arrows come with #1 cable. Has worked great!
The bigger the better within reason. Less electrical loss for a long run.
Steve H.
Moose 213
Legeorgen@aol.com
Sent: Sunday, May 25, 2003 5:53 PM
Subject: Re: Electrical Connectors
Rick,
winter.
Bruce 357R
Murray and Carol Cherkas
Post by Murray and Carol Cherkas » Fri Feb 17, 2012 11:08 pm
Hello Rick;
Tony Bingellis' shows a 1/0. This is what I put in. I bought a 1/0 welding
cable which is very flexible.And yes it does weigh a few pounds. I'm
building a rebel. Also bought an Oddysey PC680 battery installed as far back
as the floor allowed.Put the battery on one side of the hat track and the
ELT on the other.
GOOD luck
Murray
Steve Halvorsen
Sent: Sunday, May 25, 2003 12:14 PM
the box, ect.
Steve H.
Moose 213
Rickhm at home
Rick Muller
SR70
T
PK
Post by PK » Fri Feb 17, 2012 11:08 pm
Re aluminum starter cables:
Aluminum is slightly less conductive than copper, so going one size up
usually solves this problem. It will still be significantly lighter than
copper.
The big diff between aluminum and copper is that aluminum oxide is not
conductive whereas copper oxide is (less conductive than nonoxidized copper,
but still conductive). The problem with aluminum is in termination. One must
scrape (scotchbrite) aluminum oxide off and then quickly clamp wire between
washers, maximizing contact surface area as much as possible. This terminal
will heat and cool during startups. If neglected it will become loose over
time and lose contact (may even start sparking and melting!!!!). The
BIGGEST MISTAKE is to just tighten this terminal and think that problem is
solved. You must first take it apart do the scotchbrite and quickly clamp
again. This may need to be done periodically (perhaps annually?). Alum
terminals should be kept accessible so that tightness can be inspected
regularly.
There are goops to seal possible spark. I am not familiar with them, perhaps
someone else can comment.
Most of the world is wired with aluminum, every big transformer, every
welding machine, every hydroline in the country. There are all kinds of
termination methods for it, just has to be done right and maintained.
But if you want peace of mind, less hassle and dont mind the added weight,
go with copper.
Paul Kucera
Rebel builder 453R
David Sowder
Post by David Sowder » Fri Feb 17, 2012 11:08 pm
From an electrical type person and an aluminum company
employee:
1. Always use a connector that designed for aluminum
or aluminum/copper.
2. Always use a joint compand, liberally, your local
electrical supplier will have several. NoAllox or
Alcoa2. I have used both for low and high voltage
connections and have never had any problems. These
compounds prevent corrosion and moisture build up in
the joint. Moisture will cause the aluminum to corrode
and turn back into a white, non-conductive powder
(heat/sparks/fire).
3. If you are going to use aluminum wire, frequent
check of the conection(s) is mandatory. Checking for
both corrosion and tightness of the connection. Copper
connections still need to be checked also, but not as
often as aluminum.
Mike Sowder
--- klehman@albedo.net wrote:
I'd consider one of those joint compounds mandatory.
Think mine is
called NoAllox. Otherwise corrosion will occur, heat
will occur.
Aluminum tends to flow a bit in a connection so
mechanical pressure
alone won't guarantee a gas tight corrosion free
connection. Problem is
much worse if connectors specifically designed for
aluminum are not
used. This problem has resulted in a high incidence
of fire in houses
before the joint compound was mandated.
copper.
regularly.
go with copper.
Paul Kucera
Rebel builder 453R
Archives located at
David M Sowder RCDD/LAN Specialist
Simple Technology Solutions, Inc.
(812) 925-8240 (voice/fax)
(812) 204-2320
__________________________________
Do you Yahoo!?
Yahoo! Calendar - Free online calendar with sync to Outlook(TM).
http://calendar.yahoo.com
klehman
Post by klehman » Fri Feb 17, 2012 11:08 pm
I'd consider one of those joint compounds mandatory. Think mine is
called NoAllox. Otherwise corrosion will occur, heat will occur.
Aluminum tends to flow a bit in a connection so mechanical pressure
alone won't guarantee a gas tight corrosion free connection. Problem is
much worse if connectors specifically designed for aluminum are not
used. This problem has resulted in a high incidence of fire in houses
copper.
regularly.
go with copper.
Paul Kucera
Rebel builder 453R
Dave-Sandra
Post by Dave-Sandra » Fri Feb 17, 2012 11:08 pm
From this Powerlineman to you!!!!
That goop you see the hydro crews putting on the ends of the aluminum wire
is a contact paste ( anti oxidant )
There are various manufacturers ie; Ideal, NoAlox , Kearney as well as many
others .As others have stated make sure you use a connector specificaly
designed for Al and follow the manufaturers directions on the prduct you are
using (some say coat the connector and wire others say to wire brush the
paste into the wire....... Just my two bits, but I personally would stay
away from aluminum wire in any area that is subject to vibration as it WILL
work harden and fail over time. Not trying to stick my nose into anybodies
buisness but I watched my dad spend 9 years building his Christavia and
would hate to see someone lose their plane to fire from trying to save a few
pounds . sorry if I have offended any aluminum users as I said Just my two
bits
(thats just a little over 2 cents to you American guys once we add freight
s/h and the exchange lol )
Dave Bjorkman
(Future Mosse builder and avid forum lurker )
Rebflyer@aol.com
Sent: Wednesday, May 28, 2003 9:12 AM
In watching the local electrical service company install the aluminum wire
connection from the pole to the meter I noticed them covering the connection
with some kind of paste. Must be an anti oxidizer of some kind. Anybody have
an idea? I'll look too. It's gotta help. Curt N97MR
Rebflyer
Post by Rebflyer » Fri Feb 17, 2012 11:08 pm
In watching the local electrical service company install the aluminum wire connection from the pole to the meter I noticed them covering the connection with some kind of paste. Must be an anti oxidizer of some kind. Anybody have an idea? I'll look too. It's gotta help. Curt N97MR
dmp
Post by dmp » Fri Feb 17, 2012 11:08 pm
I believe copper actually work hardens worse than aluminum does.
David Parrish
The Town of Milton is FULL of houses with Aluminum Wire (as I'm sure are
other towns before it was outlawed!), so watch what you buy there! I almost
lost my house on Graham Bell Court in '84 before I realized what I had.
After that it was a yearly ritual to pull every receptacle/switch out of the
walls and retighten all the terminals (and they were loose every time!)
Sent: Wednesday, May 28, 2003 8:27 AM
copper.
copper,
must
between
terminal
over
is
clamp
regularly.
perhaps
weight,
go with copper.
Paul Kucera
Rebel builder 453R
