rebel tail section bulletin 100594rb-3
vlemasters
Post by vlemasters » Fri Feb 17, 2012 5:57 pm
Hi guys,
We have been lurking on this list for a short while and find that we need your help already.
We have been slowly working on rebel kit #411 and are just now starting the fuselage kit. The bulletin says that the extension (doubler?) goes inside the fuselage side skin fus-23. It looks like to me that the side skins are fus 22's. The sketch shows fus 23 and I am assuming that is correct however it seems that fus 22 would be the stronger of the two options. I hope that the sketch is correct as I made 1 to fit inside fus 23 this evening but thought I had better wait until I heard from some of you guys before I made another one.
Thanks in advance for your help
David Williams
Vern Lemasters
Wray Thompson
Post by Wray Thompson » Fri Feb 17, 2012 5:57 pm
Guys I scanned in the notes I made when talking to Wayne regarding this last year and put a copy of it on my home page under construction. Just click on the Fus22Dblr under other stuff or click here http://webhome.idirect.com/~wrayt/fus22doubler.jpg I had a piece of .032 so I used that for my doublers.
Vern Lemasters wrote:
Hi guys,We have been lurking on this list for a short while and find that we need your help already.We have been slowly working on rebel kit #411 and are just now starting the fuselage kit. The bulletin says that the extension (doubler?) goes inside the fuselage side skin fus-23. It looks like to me that the side skins are fus 22's. The sketch shows fus 23 and I am assuming that is correct however it seems that fus 22 would be the stronger of the two options. I hope that the sketch is correct as I made 1 to fit inside fus 23 this evening but thought I had better wait until I heard from some of you guys before I made another one.Thanks in advance for your helpDavid WilliamsVern Lemasters
Wray Thompson ...Rebel 306 ...home page http://webhome.idirect.com/~wrayt/
My ICQ number is 29764664
