Craig,
I feel your pain!! There will be days that you are glad you are several thousand miles away from MAM. It's those days that you feel that if the guy that wrote the manual was there, you might be knocking th snot out of him! JK On those days its best just to walk away for a bit, calm down, and do something else for awhile.
Craig Walls <snowyrvr@mtaonline.net> wrote:
Well, I am really struggling with this fin. This is as much a venting as it
is a cry for help. I have built the dang thing twice now; two front spars,
two rear spars, 2 sets of ribs, etc. The first time I had it together
except for the leading edge skin but didn't rivet it because it wouldn't lie
flat. I decided I was pulling it up or out of shape with the skin so I
remade the ribs and spars (save the skins!).
Today I had it pretty flat and riveted one skin on but the other side was a
#%#@!! and the second set of L E skin holes didn't match up and actually,
skin didn't perfectly match the ribs and spars either. Looks like I'll be
paying MAM a visit for some parts/pieces.
I'm using lots of clecos, working carefully, etc. It's quite a job getting
the edges to match up with all of those creases in the skin. There must be
some trick to building ribs and spars accurately when they don't even lie
flat on the skin!
The worst of it is that I read ahead and I know there's pretty much more of
the same thing in the rest of the control surfaces section!
If you have no hints or suggestions, a sympathetic moment of silence will
do. Lol craig R207
Get easy, one-click access to your favorites. Make Yahoo! your homepage.
[rebel-builders] Need to Vent!
Craig,
You do have BOTH skins clecoed on before doing any riveting right?
Your smile counts. The more smiles you share, the more we donate.
_________________________________________________________________From: snowyrvr@mtaonline.net
Subject: [rebel-builders] Need to Vent!
Date: Sun, 18 Nov 2007 21:53:05 -0900
flat on the skin!
do. Lol craig R207
Hi Jesse,
Do you mean have one side clecoed while I'm riveting the other? If so,
then no. I fitted one skin, flipped it over on some supports (with clecos
in place) and then fit the other side. When I assembled them I just did
one side at a time.
Original Message:
Date: Mon, 19 Nov 2007 07:53:36 -0800
Subject: RE: [rebel-builders] Need to Vent!
Craig,
one side at a time.
Original Message:
Craig,
itFrom: snowyrvr@mtaonline.net
spars,is a cry for help. I have built the dang thing twice now; two front
lietwo rear spars, 2 sets of ribs, etc. The first time I had it together
aflat. I decided I was pulling it up or out of shape with the skin so I
getting#%#@!! and the second set of L E skin holes didn't match up and actually,
bethe edges to match up with all of those creases in the skin. There must
ofsome trick to building ribs and spars accurately when they don't even lie
flat on the skin!
_________________________________________________________________the same thing in the rest of the control surfaces section!
do. Lol craig R207
Something doesn't sound right. If you have repeated troubles restarting
with the same skins perhaps there is something wrong with the skins. It has
been many years since I built mine but I remember the control surface
construction as being very cookbook with no fitting problems. I just
followed the manual step by step assuming it would lead to the finished
product. (Don't do that for the wings and fuselage. That's where the
manual starts deteriorating.) I do completely agree with Jesse about having
the entire assembly clecoed before setting any rivets.
044SR
Sent: Monday, November 19, 2007 10:39 AM
Hi Jesse,
one side at a time.
Original Message:
Craig,
044SR
Hi Jesse,
one side at a time.
Original Message:
Craig,
flat on the skin!
do. Lol craig R207
Craig, That may be the problem. I remember having the whole thing clecoed before any riveting.
Jesse> From: snowyrvr@mtaonline.net> To: rebel-builders@dcsol.com> Subject: RE: [rebel-builders] Need to Vent!> Date: Mon, 19 Nov 2007 14:39:22 -0500> > Hi Jesse,> Do you mean have one side clecoed while I'm riveting the other? If so,> then no. I fitted one skin, flipped it over on some supports (with clecos> in place) and then fit the other side. When I assembled them I just did> one side at a time.> > Original Message:> -----------------> From: Jesse Jenks jessejenks@hotmail.com> Date: Mon, 19 Nov 2007 07:53:36 -0800> To: rebel-builders@dcsol.com> Subject: RE: [rebel-builders] Need to Vent!> > > > Craig,> You do have BOTH skins clecoed on before doing any riveting right?> > > From: snowyrvr@mtaonline.net> > To: rebel-builders@dcsol.com> > Subject: [rebel-builders] Need to Vent!> > Date: Sun, 18 Nov 2007 21:53:05 -0900> > > > Well, I am really struggling with this fin. This is as much a venting as> it> > is a cry for help. I have built the dang thing twice now; two front> spars,> > tw
ribs, etc. The first time I had it together> > except for the leading edge skin but didn't rivet it because it wouldn't> lie> > flat. I decided I was pulling it up or out of shape with the skin so I> > remade the ribs and spars (save the skins!).> > > > > > > > Today I had it pretty flat and riveted one skin on but the other side was> a> > #%#@!! and the second set of L E skin holes didn't match up and actually,> > skin didn't perfectly match the ribs and spars either. Looks like I'll be> > paying MAM a visit for some parts/pieces.> > > > > > > > I'm using lots of clecos, working carefully, etc. It's quite a job> getting> > the edges to match up with all of those creases in the skin. There must> be> > some trick to building ribs and spars accurately when they don't even lie> > flat on the skin! > > > > > > > > The worst of it is that I read ahead and I know there's pretty much more> of> > the same thing in the rest of the control surfaces section!> > > > > > > > If you have no hints or
e
tic moment of silence will> > do. Lol craig R207> > > > > > > > > > > > > > > > > > > > -----------------------------------------------------------------> > List archives located at: https://mail.dcsol.com/login> > username "rebel" password "builder"> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com> > List administrator: mike.davis@dcsol.com> > -----------------------------------------------------------------> > > > > > > > _________________________________________________________________> Your smile counts. The more smiles you share, the more we donate. Join in.> http://www.windowslive.com/smile?ocid=T ... lhmtagline> > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > > > > > --------------------
------------------------> mail2web.com
e
