[rebel-builders] Pitot location
Post by Bob Patterson » Sun Feb 19, 2012 7:05 pm
Hi Charlie !
Many builders have just used a piece of tubing hung
from straps on the bottom of the wing, or fastened to
the top strut fairing. The tube runs down inside the
strut, exiting in a convenient place for a water drain,
and easier to hook up to the back of the panel than
trying to run along the wing & down from the root.
You can get quick-connects for the tube, making
it easy to remove the wings.
I've heard the ideal position is about 3" below
the wing, about 1/3 chord back ....
http://www.prosumers.ca
On Friday 16 November 2007 19:48, Charlie Eubanks wrote:
[quote]Hello All
I am starting to assemble the left wing and I would like to provide
suitable mounting in the leading edge ribs for
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 7:05 pm
Bob P
Maybe I spoke to soon. After more searching I found a bunch of "E" mail
about "Tube for wiring in the wing" which included location for the pitot
tube. Thanks for the reply.
Charlie E.
Sent: Friday, November 16, 2007 1:48 PM
Subject: [rebel-builders] Pitot location
[quote]Hello All
suitable
[rebel-builders] Pitot Location
Post by Drew Dalgleish » Sun Feb 19, 2012 7:47 pm
At 05:14 PM 8/2/2008 -0800, you wrote:
Hi Fellas,
I was wondering if there's a "best" place to locate the pitot on my rebel.
I'm looking online for general info but thought there might be some
experience with the rebel that would be good to know. The Falcon brand unit
I bought came with zero info. It is heated. I'm installing on the left
wing.
Thanks in advance. Craig
Hi Craig Most rebels have the pitot in the same rib bay as the lift strut
attach point. That's far enough out to be past the prop and the strut keeps
you from walking into it and poking your eye out. It also makes a nice
plumbing run for the tubing to go down the strut and into the cabin at the
bottom instead of at the wing root.
Post by Craig Walls » Sun Feb 19, 2012 7:47 pm
Thanks Drew. Kind of what I was thinking. It's always good to hear some
others with experience before you cut the wing skin. :) Craig
Dalgleish
Sent: Saturday, August 02, 2008 7:34 PM
Subject: Re: [rebel-builders] Pitot Location
Hi Fellas,
unit
wing.
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 7:47 pm
Hi Craig
Fresh back from Osh. I put mine in the round inspection cover just beyond the strut.
Steve W. 637R
Try Chicktionary, a game that tests how many words you can form from the letters given. Find this and more puzzles at Live Search Games!
http://g.msn.ca/ca55/207
Thanks to all who answered the pitot question. I ended up putting it in the
bay between 5 and 6 forward of the strut. CW
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of steve
whitenect
Sent: Sunday, August 03, 2008 12:55 PM
Subject: RE: [rebel-builders] Pitot Location
Hi Craig
the strut.
Steve W. 637R
