Hi Guys!
So I built Flaperon number one, and I carefully applied AFS Waterborne Poly Primer/Sealer to it as a preservative coating. And despite the claim from the AFS factory that it was compatible with fabric coating systems, I wiped a little MEK on it as a test and it...failed. Came right off. Bummer!
I am told that, because fabric glue uses MEK as a thinner, AFS is a non-starter now. So, what to do?
Obviously, I can take off the coating on the flanges and skin that will touch fabric glue. What do I put on those surfaces? Zinc chromate? Two part Poly from Dupont? Nothing?
What do I coat the other three frames with?
Thanks!
Rich
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
