[rebel-builders] Covering Flapperons
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 2:16 pm
the poly fiber manual has all steps details and does not cost to much
thats what i am using for a reference, have you got an iron, what is it
mike#007
pequeajim@dcsol.com
Sent: Monday, October 16, 2006 12:12 PM
Subject: [rebel-builders] Covering Flapperons
I did a search for some feedback on covering the Rebel flapperons and
happily
found some references to a step or two that is not detailed in the murphy
instructions. My question is that, although quite proficient at covering
large
model wings, some of the terms relating to the full scale covering are new
me.
Has anyone on here detailed step by step the covering process? I'm not
worried about getting it done, just about forgetting something that I should
have done that was not explained in the build manual.
pequeajim
Post by pequeajim » Sun Feb 19, 2012 2:16 pm
Thanks Mike:
I have a fairly large iron that I used for covering my my 45% RC aircraft. It is
a bit bigger than the standard RC hobby irons. It will go to 400 degrees.
What do you use?
On 10/16/2006 8:21 AM, michael.jones@snclavalin.com wrote to rebel-
builders:
-> the poly fiber manual has all steps details and does not cost to much
-> thats what i am using for a reference, have you got an iron, what is it
-> mike#007
-> -----Original Message-----
-> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of
-> pequeajim@dcsol.com
-> Sent: Monday, October 16, 2006 12:12 PM
-> Subject: [rebel-builders] Covering Flapperons
-> I did a search for some feedback on covering the Rebel flapperons and
-> happily
-> found some references to a step or two that is not detailed in the murphy
-> instructions. My question is that, although quite proficient at covering
-> large
-> model wings, some of the terms relating to the full scale covering are new
-> to
-> me.
-> Has anyone on here detailed step by step the covering process? I'm not
-> worried about getting it done, just about forgetting something that I should
-> have done that was not explained in the build manual.
-> List archives located at: https://www.dcsol.com/login
Jones, Michael
cant find iron that has no autoshut off and goes to 350, what is make of
yours
pequeajim@dcsol.com
Sent: Monday, October 16, 2006 12:53 PM
Subject: RE: [rebel-builders] Covering Flapperons
Thanks Mike:
It is
What do you use?
builders:
-> mike#007
-> happily
-> large
new
-> to
-> me.
should
Post by Drew Dalgleish » Sun Feb 19, 2012 2:16 pm
Buy your mother a new one and steal her old one :) or check out garage
sales. I found that the old iron I have used for waxing skis since I was a
teenager (and it was old then) holds it's temperature within 5 degrees
after I calibrated it.
yours
pequeajim@dcsol.com
Thanks Mike:
It is
What do you use?
builders:
-> mike#007
-> happily
-> large
new
-> to
-> me.
should
happily
large
me.
Fabric covering is easy. Just pick the system you want to use and follow
the manufacturers instructions.
Post by Ken » Sun Feb 19, 2012 2:16 pm
Yes you will want that Polyfiber covering manual if using polyfiber
products.
I used 3 quarts of silver and 4 quarts of the pink polybrush so a gallon
of each is probably the cheapest way to buy chemicals. The small can of
glue ( a pint I think) was way more than I needed.
You may want to purchase the necessary tapes as for me it was very time
consuming trying to get the 3" wide tape down smooth on the trailing
edge. MAM said to cut that from excess covering material but mine had
folds and creases in it that did not want to lay down flat. And the edge
of my homemade tape is a bit ragged.
An old clothes iron worked fine for me as well once calibrated with
their thermometer as per the polyfiber manual. And don't forget a few
vent washers or seaplane vents.
For anyone attending Oshkosh or Sun'n Fun, it is worth attending the
polyfiber covering workshop for a couple of hours of hands on experience
and to get the idea of how the process works. Nothing difficult about it
once you see it.
happily
large
me.
pequeajim
Mine does not have an autoshutoff, but it does go to 350 degrees. I bought
it from hHorizon Hobbies about 6-7 years ago. It was called a Hanger 9 Giant
Scale iron and I don't believe they still make it, but you can check.
Here is the smaller Hanger 9 Iron
http://www.horizonhobby.com/Products/De ... dID=HAN135
Here's some from Hobby Lobby
http://www.hobby-lobby.com/heatgun.htm
And from Tower Hobbies
http://www2.towerhobbies.com/cgi-bin/wt ... XB361&P=ML
I looked around for you and could not find the larger ones. I will try tonight
and send you a link if I find it.
Jim!
On 10/16/2006 8:58 AM, michael.jones@snclavalin.com wrote to rebel-
builders:
-> cant find iron that has no autoshut off and goes to 350, what is make of
-> yours
-> Sent: Monday, October 16, 2006 12:53 PM
-> Subject: RE: [rebel-builders] Covering Flapperons
-> Thanks Mike:
-> I have a fairly large iron that I used for covering my my 45% RC aircraft.
-> It is
-> a bit bigger than the standard RC hobby irons. It will go to 400 degrees.
-> What do you use?
-> On 10/16/2006 8:21 AM, michael.jones@snclavalin.com wrote to rebel-
-> builders:
-> -> the poly fiber manual has all steps details and does not cost to much
-> -> thats what i am using for a reference, have you got an iron, what is it
-> -> mike#007
-> -> -----Original Message-----
-> -> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of
-> -> pequeajim@dcsol.com
-> -> Sent: Monday, October 16, 2006 12:12 PM
-> -> To: rebel-builders@dcsol.com
-> -> Subject: [rebel-builders] Covering Flapperons
-> -> I did a search for some feedback on covering the Rebel flapperons and
-> -> happily
-> -> found some references to a step or two that is not detailed in the
murphy
-> -> instructions. My question is that, although quite proficient at covering
-> -> large
-> -> model wings, some of the terms relating to the full scale covering are
-> new
-> -> to
-> -> me.
-> -> Has anyone on here detailed step by step the covering process? I'm
not
-> -> worried about getting it done, just about forgetting something that I
-> should
-> -> have done that was not explained in the build manual.
-> -> List archives located at: https://www.dcsol.com/login
-> -> username "rebel" password "builder"
-> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> List administrator: mike.davis@dcsol.com
pequeajim
Thanks Ken:
I just ordered the 3" tape from them, their book and DVD.
I've covered a LOT of RC aircraft, so I think after watching the DVD, I should
have the hang of it.
On 10/17/2006 4:11 AM, klehman@albedo.net wrote to rebel-builders:
-> Yes you will want that Polyfiber covering manual if using polyfiber
-> products.
-> I used 3 quarts of silver and 4 quarts of the pink polybrush so a gallon
-> of each is probably the cheapest way to buy chemicals. The small can of
-> glue ( a pint I think) was way more than I needed.
-> You may want to purchase the necessary tapes as for me it was very time
-> consuming trying to get the 3" wide tape down smooth on the trailing
-> edge. MAM said to cut that from excess covering material but mine had
-> folds and creases in it that did not want to lay down flat. And the edge
-> of my homemade tape is a bit ragged.
-> An old clothes iron worked fine for me as well once calibrated with
-> their thermometer as per the polyfiber manual. And don't forget a few
-> vent washers or seaplane vents.
-> For anyone attending Oshkosh or Sun'n Fun, it is worth attending the
-> polyfiber covering workshop for a couple of hours of hands on experience
-> and to get the idea of how the process works. Nothing difficult about it
-> once you see it.
-> Ken
-> Drew Dalgleish wrote:
-> >At 08:11 AM 10/16/2006 -0800, you wrote:
-> >>I did a search for some feedback on covering the Rebel flapperons and
-> >happily
-> >>found some references to a step or two that is not detailed in the
murphy
-> >>instructions. My question is that, although quite proficient at covering
-> >large
-> >>model wings, some of the terms relating to the full scale covering are
new
-> >to
-> >>me.
-> >>Has anyone on here detailed step by step the covering process? I'm
not
-> >>worried about getting it done, just about forgetting something that I
should
-> >>have done that was not explained in the build manual.
-> >Fabric covering is easy. Just pick the system you want to use and follow
-> >the manufacturers instructions.
-> >Drew
Jones, Michael
thanks jim
pequeajim@dcsol.com
Sent: Tuesday, October 17, 2006 1:24 PM
Giant
tonight
Jim!
builders:
-> yours
-> Thanks Mike:
aircraft.
-> It is
degrees.
-> What do you use?
-> builders:
it
-> -> mike#007
-> -> happily
murphy
covering
-> -> large
-> new
-> -> to
-> -> me.
not
-> should
tlmcclary@juno.com
Post by tlmcclary@juno.com » Sun Feb 19, 2012 2:16 pm
Try www.poly-fiber.com and then click misc. covering supplies. They
list a fabric iron and a hobby iron.
These people, Jim and Dondie (? spelling), teach fabric at Oshkosh and
Sun-N-Fun. Good people and if you have a problem, call their business
and they will have the answer.
Terry
R666
bought
9 Giant
try tonight
Jim!
builders:
make of
-> yours
-> Thanks Mike:
aircraft.
-> It is
degrees.
-> What do you use?
-> builders:
much
what is it
-> -> mike#007
Behalf Of
flapperons and
-> -> happily
murphy
covering
-> -> large
covering are
-> new
-> -> to
-> -> me.
I'm
not
that I
-> should
Jones, Michael
good idea terry, did not even think to see if poly-fiber has an iron, will
order theirs tonight and get this stupid project done finally
tlmcclary@juno.com
Sent: Tuesday, October 17, 2006 3:09 PM
Terry
R666
bought
9 Giant
try tonight
Jim!
builders:
make of
-> yours
-> Thanks Mike:
aircraft.
-> It is
degrees.
-> What do you use?
-> builders:
much
what is it
-> -> mike#007
Behalf Of
flapperons and
-> -> happily
murphy
covering
-> -> large
covering are
-> new
-> -> to
-> -> me.
I'm
not
that I
-> should
[rebel-builders] Covering flapperons
Post by Wayne G. O'Shea » Sun Feb 19, 2012 2:16 pm
Rivets....leave the stitching for your classic J3!
Sent: Wednesday, October 18, 2006 10:32 PM
Subject: [rebel-builders] Covering flapperons
I just watched the Poly Fiber video, very informative. I do want to ask
you
all. Did you stitch the ribs, or rivet them?
pequeajim
Are there specific fabric rivets, or did you use plastic washers?
On 10/18/2006 6:36 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Rivets....leave the stitching for your classic J3!
-> From: <pequeajim@dcsol.com>
-> Sent: Wednesday, October 18, 2006 10:32 PM
-> Subject: [rebel-builders] Covering flapperons
-> >I just watched the Poly Fiber video, very informative. I do want to ask
-> >you
-> > all. Did you stitch the ribs, or rivet them?
-> > List archives located at: https://www.dcsol.com/login
Use the large head fabric rivets that came with the kit! :O) 7402's !
Sent: Wednesday, October 18, 2006 10:57 PM
Subject: Re: [rebel-builders] Covering flapperons
ask
-> >you
