Don't know about a US source, but there is a method to the naming vs.
size...
The first number is the type of rivet, the second is the diameter, and the
third and fourth are the grip length. Here are the most common rivets we
use.
RV-1410 1/8" X 3/16"
RV-1414 1/8" X 5/16"
RV-1613 3/16" X 1/4"
RV-1619 3/16" X 3/8"
RV-1621 3/16" X 1/2"
RV-4412 1/8" X 3/16" COUNTERSUNK
RR-5404 1/8" X 1/4" STAINLESS STEEL
RR-5406 1/8" X 3/8" STAINLESS STEEL
RR-5604 3/16" X 1/4" STAINLESS STEEL
RR-5606 3/16" X 3/8" STAINLESS STEEL
RR-6403 1/8" X 3/16" CLOSED END (TYPICAL TANK RIVET)
Sent: Tuesday, October 10, 2006 7:02 PM
Subject: [rebel-builders] Avex rivet source?
I've been looking around the web and can't seem to readily find a source
for
the Avex RV-1410 or RV-4412 rivets (besides Murphy that is). I'd like to
find a U.S. source.
I know that Aircraft Spruce lists the Cherry BSP & BSC as roughly
equivalent
(I may end up ordering these if I can't find a good source for Avex ones).
ACS also has some Avex (as do a couple of other places), but they are
different (e.g. 1601-0410 series??) than the RV-xxxx numbering series
found
in the Murphy manual.
Anyone found a U.S. based source for the Avex rivet?
Last, is there any rhyme or reason to the Avex numbering scheme? E.G. an
RV-1410 is 1/8" x 3/16"--other than memorizing such?
Thank you!
