Did you go for the fat one or the standard? I don't know if the rebel tail
could handle the big one, but it sure looks cool.
Jesse
Subject: Re: [rebel-builders] Scott tail wheel
Date: Tue, 03 Oct 2006 18:06:37 -0800
Hi Ian,
Take a look at WagAero.com Spring Connector Kit, Tension Type, FAA/PMA'd
Model: SKU: D-205-000. Attaches tailspring to tailwheel. Includes 2
springs, 2 connector clips and 2 linkage chains. $19.95.
This is what I bought for my Alaska Bushwheel (the new Scott 3200). They
are as Wayne described.
Roger Hoffman #687R
Eugene, OR USA!
On 10/3/2006 4:23 PM, allsure@bigpond.net.au wrote to rebel-builders:
-> G'day again
-> Now I am confused!
-> I will upgrade my springs from MAM to the proper Scott springs. But just
-> what spring set should I use?
-> Is ACS a good place to buy them?
-> Thanks and regards
-> Ian
-> : BTW...spring coil is 1" diameter x 1 7/8 long. Overall length with
spring
-> : hooks is approx 3 3/8"
