[rebel-builders] Elite
Jeffrey Steenson
Post by Jeffrey Steenson » Sun Feb 19, 2012 2:04 pm
Dear Mike,
It comes off no problem. I had to reglass some of it because the gelcoat
cracked. The factory fiberglass work won't win any prizes!
Jeffrey Steenson
E714
Sent: Friday, August 18, 2006 7:13 PM
Subject: [rebel-builders] Elite
Hi group,
I recently bought the tail fairing after my own attempt failed. I just
couldn't make it smooth enough, I knew there was a reason I built a metal
plane! The purchased fairing came in 2 pieces, a RS and LS. I am told to
glass the halves together. Does it come off ok as a 1 piece item? Looks
like you may have to fight the flare of the tail cone as you pull it
forward and then off.
I also installed the ground handler kit, it sure is a nice piece and good
idea.
Mike Betti
771E
Post by Wayne G. O'Shea » Sun Feb 19, 2012 2:27 pm
You're not supposed to do the math until 6 months after the first flight !!
Sent: Thursday, November 30, 2006 9:45 PM
Hi all,
Made a big mistake today. You know all those receipts you been throwing in
the corner to finish your kit. Well, I went and added them all up
Any one have an idea what a completed Elite on wheels is worth in the US?
Any way, I am about 99% complete. I have to fit the wing tips, make some
sort of ladder step, and fit inspection covers to the wing control
surfaces and that will be it. Possibly a flight late January depending on
the winter we are having. I don't know if that time of the year is any
good for breaking in an engine other than the shock cool issue.
Mike Betti
N771ME
Post by Bob Patterson » Sun Feb 19, 2012 2:27 pm
Hi Mike !
Sounds GREAT !!! Keep plugging !
January should be ok for test flying - it'll be wide open
most of the flight anyway, and that will help avoid any cooling
problems !! ;-) :-)
As usual, fly with just over half tanks, and about 50 lb. tied
down in the baggage area..... use 1 notch flaps for takeoff with
the Elite, and 2 for landing. (The Rebel takes 'full' for both !)
Taxi a bit first, doing circles, to seat the brakes, and get used
to the tailwheel kick-out.
http://www.prosumers.ca
On Thursday 30 November 2006 09:45 pm, Mike Betti wrote:
Hi all,
up .................................$$!
sort of ladder step, and fit inspection covers to the wing control surfaces
and that will be it. Possibly a flight late January depending on the winter
we are having. I don't know if that time of the year is any good for breaking
Mike Betti
N771ME
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 2:27 pm
Mike,, I'm just hoping my wife never decides to add them all up. When she
sees something new (she is observant about some things) ,, I always tell her
it's been here for a while I just decided to get it out. It's just a
technicality awhile can be 5 minutes , 5 hours , 5 days, or longer... Dale
SR-033
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 2:27 pm
Those were going to be my next questions. How do I fly it?
Thanks Bob,
Sent: Thursday, November 30, 2006 9:01 PM
Subject: Re: [rebel-builders] Elite
Hi Mike !
problems !! ;-) :-)
Hi all,
in
surfaces
winter
breaking
Mike Betti
N771ME
Good thing you send her to town during the normal Fedx delivery times Dale !
LOL
Sent: Thursday, November 30, 2006 10:05 PM
her
SR-033
Kevin & Nancy Mayville
Post by Kevin & Nancy Mayville » Sun Feb 19, 2012 8:15 pm
Hey Builders
When I got my Rebel I also had brake problems with inadequate brake
pressure, as it turned out the geometry of the master cylinders, they were
mounted on the rudder pedal up right tubes. Murphy has a upgrade that shows
the master cylinders mounted on the floor. which I did and now my brakes are
prefect. ( before I changed the geometry I could only hold the plane back at
1800 rpm with a LOT of pedal pressure and now a can hold at full throttle )
Do the VG's slow don your cruise at all ?
I am a new tail dragger pilot with a total 16 hours and so far my landings
are not too bad !
Kevin
C-FRFP
Sent: Friday, February 13, 2009 8:55 PM
Hi builders,
I been out of touch with the group for a year and a half and had to see
how
it was going out there. I been in contact with a couple builders since and
discussed some problems.
My Elite now has been flying for 2 years and about 110 hours. It is such a
great airplane! It seems to have the best of both worlds in short field
cruise. I add VG's to it about a year ago which knocked 10 mph off my
stall.
I still don't have the greatest brakes, maybe ok for a tail dragger but
wish
I had a bit more. I believe the problem is inadequate brake pressure due
geometry, but I haven't measured it with a gauge yet. I did recently
replace
my pads and found out for some reason I can't get long enough rivets. Does
anybody know what the deal is here. My back plates are aluminum and about
twice as thick as the steel ones in certified aircraft. I ended up machine
countersinking the rivets deeper into the backplate so that standard
rivets
would work. Maybe I weakened them by doing this?
I see some disappointment with MAM in some recent letters, I used to get
frustrated too when I was building. Hang in there the airplane is great
worth the effort.
Mike Betti
N771ME
Roger Cole
Post by Roger Cole » Sun Feb 19, 2012 8:46 pm
Bernard,
I have been using smarois@murphyair.com. He responds, but it may
take a day or two because he is very busy.
Roger Cole
Murphy Elite #709
rcole927@earthlink.net
On Nov 14, 2009, at 4:47 PM, bernard.liagre@dcsol.com wrote:
Hello Bob ,
I have read the procedure to follow to buy a windshield and the engine
cowlings polyester for the Elite, I may have the wrong e mail, because
Murphy did not respond, can you confirm the 'e-mail address is what
Stephane Marois will always work ?
thank you for response
Best regards
Bernard
David A. Ricker
Post by David A. Ricker » Sun Feb 19, 2012 8:46 pm
Don't hold your breath on it. Its been 3 weeks so far on their "we'll
get back to you in a week or two" promise.
We asked for information/quote on the cowling etc. also. <Humor>Maybe
we should have mentioned windshields.......;-P</Humor>
Elite583.cjb.net
Hello Bob ,
Best regards
Bernard
Checked by AVG - www.avg.com
Version: 8.5.425 / Virus Database: 270.14.65/2503 - Release Date: 11/14/09 19:42:00
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 11:06 pm
Hello Rob.
Like others, I didn't like the simple crush tube. I used standard aluminum
bar stock and filed it to fill the structural square tube. Pics at:
http://www.efogelin.com/aviation/murphy ... index.html
I have been on floats and standard gear for two years and 200 hours and have
had no problems.
The rudder and elevator horn mods are not for improving handling. The
elevator mod is a Service Bulletin. I believe that there was either horn
and/or spar cracking. So, this is for additional support.
The rudder horn mod is a Service Bulletin on the Moose. Other Elite owners
have done this on the Elite as we have more similar tails to a Moose than a
Rebel.
These are safety mods, not handling issues.
Elite N645E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rob
Maxwel
Sent: Monday, November 22, 2010 11:25 AM
Hi All
About to carry out the mod on the gear installing the alloy blocks to
strengthen this up. Has anyone had any problems with your spring gear after
completing the Mod?
Also curious about the value of the rudder and elevator horn mod to improve
handling?
Regards
Rob Maxwell
New Zealand.
N.Smith
Post by N.Smith » Sun Feb 19, 2012 11:06 pm
Hi Rob
The gear mod is a great idea, helps prevent crushing of the forward FUS-5
tube.
The elevator spade leading edge mod is a good idea to improve flight
handling, reducing a pitch instability caused by the slabby front end of the
original.
I think most people leave the rudder spade leading edge as is.
Nig
745E
_____
Maxwel
Sent: 22 November 2010 19:25
Hi All
completing the Mod?
handling?
Regards
Rob Maxwell
New Zealand.
_____
No virus found in this message.
Version: 10.0.1153 / Virus Database: 424/3272 - Release Date: 11/22/10
_____
