Mike small ones are the little guys on C-65's that look like grommets!
On the normal Lycoming rubbers for conical mounts there is a dimension that
you should have between the pad and the large washer on the other side once
you tighten them down. I can't remember the dimension...or where I put the
#....but since you have the steel insert aerobatic 6230's it doesn't really
matter.
If you followed my information/measurements that I took the time to get you
on the 31st...your welcome btw....and bought the same length bolts and have
a big ass thick washer on the forward side of it to retain the lord
mount..then like Ken says TLAR and the cotter pin should drop in the bolt
hole to boot!
Michael.Jones@snclavalin.com>
To: <
rebel-builders@dcsol.com>
Sent: Friday, June 02, 2006 9:13 AM
Subject: RE: [rebel-builders] conical engine mounting torques
HI KEN
dont know if diff between larger and smaller, only got the one size so
dont
know if i have big or small, they seem pretty firm however
mike
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com]On Behalf Of Ken
Sent: Friday, June 02, 2006 8:06 AM
To:
Subject: Re: [rebel-builders] conical engine mounting torques
Is the large one softer perhaps Mike ?
This is probably a TLAR situation.
(that looks about right) ;)
Jones, Michael wrote:
hi all
firewall wall forward by tony bingelis list following torques for rubber
mount bushings for conical engine mounts
small bushing 80 in-lbs
large bushings 40 in-lbs
i would have thought larger bushing would have higher torque value, are
these numbers backwards
anybody help on this
mike#007
List archives located at:
https://www.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
