the spare set I have in the shop to figure out what you are talking about.
Sounds to me like you have something together backwards.
Sent: Tuesday, May 09, 2006 6:03 PM
Subject: [rebel-builders] Re: Rebel Brake Calipers
alignment
Hi all
Went to assemble the calipers today and noticed that the brake pad plate
(the one that floats) is up against the caliper bracket. It is in
willwith the disk but as soon as there is some wear on the pads, the piston
eventually bend the plate. Has there been any trouble with the calipers
around the serial numbers of 637? It is not a Matco system. The only way
to use what is here is to put spacers between the axle and the caliper
bracket which would the bracket farther inside the wheel assembly.
Steve W.
