[rebel-builders] Re: Rebel - Landing Gear-Brakes
Post by Bob Patterson » Sun Feb 19, 2012 10:27 am
Whoa !! How come you have Matco's on # 333 - thought they went long
before that !! Do you have SILVER Matco wheels, or the old Gold ones ??
Sounds like you have newer axles ... the Matcos were smaller ....
Help, Wayne !!! Do you remember the diameters ????
On Tuesday 28 February 2006 08:48 pm, Jim Cole wrote:
I ran into another issue this evening and I was wondering if I'm missing
something?
The caliper mounting plate (Matco) that slides over the axle to be
attached to the flange - on the axle - only goes as far as the ridge or
increase in diameter of the axle from 3/4 to 7/8. Am I missing
something? I feel the hole in the caliper mounting plate should be 7/8
and slide right to the flange and that the ridge is for the bearing to
butt up against?? I don't have a 7/8 inch drill - any suggestions?
Jim
Rebel 333
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:27 am
Yah what colour are they Jim...I haven't made it to the shop yet!
Sent: Tuesday, February 28, 2006 9:08 PM
Subject: Re: [rebel-builders] Re: Rebel - Landing Gear-Brakes
something?
Jim
Rebel 333
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 10:27 am
I have silver Matco wheels but - gold discs - gold axle - and gold
mounting plate on the caliper?
Jim
Rebel 333
something?
Jim
Rebel 333
Maybe we can get Tom Inglis to chime in here - he has silver Matcos
on his 912 Rebel ..... and they're too skinny !! :-) Make the nice
fat DICO tires into large diameter skinny tires ... A spacer in the
center of the wheel would help !
How about it Tom ?? Do you remember how that plate installs ??
On Tuesday 28 February 2006 09:38 pm, Jim Cole wrote:
I guess the main question is - does the caliper mounting plate fit flush
to the flange on the axle?
If this is the case then I need to drill the hole out to 7/8.
Thanks for looking. I know you have even more snow than I do.
Jim
Wayne G. O'Shea wrote:
Sorry...I don't have any silver ones here to look at Jim. I remember
they had some quirks like the washer on the back "cups" after awhile
from side loads and then the bearings get sloppy. You need to resnug
the axle nut regularily till this stops.
Sent: Tuesday, February 28, 2006 9:19 PM
Jim
Rebel 333
Sorry...I don't have any silver ones here to look at Jim. I remember they
had some quirks like the washer on the back "cups" after awhile from side
loads and then the bearings get sloppy. You need to resnug the axle nut
Jim
Rebel 333
something?
Jim
Rebel 333
Jim Cole
Jim
Jim
Rebel 333
Looking at it thru mental telepathy...I imagine that step in the axle is
meant to go against the inner bearing. The torque plate is probably supposed
to float on the step area. When you assemble does it seem like the caliper
is stopping the wheel from seating where it should be? IF so then I bet the
plate needs to be opened up to fit the step like you originally suspected.
Sent: Tuesday, February 28, 2006 9:38 PM
Jim
Jim
Rebel 333
missing
or
