Wing Building CC-54
N.Smith
Wing Building CC-54
Post by N.Smith » Sat Feb 18, 2012 2:41 pm
Here's another point you'll come across soon Roger
The 1/2" spacer CC-54 that holds the torque tube laterally is drawn in the
diagram 8.26.1 in section 8.26, but it is not mentioned in the associated
text.
I had a question about the rivet size needed to hold it steady as larger
holes than required would weaken the torque tube.
Reply today from Robin...
There is no load on the spacer so the fastener is not critical.
Use RV-1410 or RV-1414, in fact you could even use an all aluminum pop
rivet of the correct length.
Just before you need to ask :-)
Nigel
745E
