3rd seat
Mike Betti
3rd seat
Post by Mike Betti » Sat Feb 18, 2012 2:33 pm
After seeing Bob's 3rd seat I was wondering is it as practical to put in the Elite? I don't plan on going on floats anytime soon and using a 180hp. Is there really enough allowance to create a 4 seat rebel and make it work? What size person goes in that back seat or 3rd seat?
Mike Betti
771E
3rd seat
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:33 pm
I could sit in the back of mine before I upholstered the seats. My daughters
can still sit back there..20 and 17 yrs old and about 5' 6 or so. I have/had
four fully adjustable seats in mine using a second seat of MAM seats and
rails (and full shoulder/lap harnesses). I removed one seat when I went to
floats to get rid of 10 lbs.... knowing it couldnt' be used for anything but
baggage retention.
The Elite is a little deeper in the rear area..so that's a plus.
I would not want to sit sideways for anything but a quick shuttle from one
field to another that where a few miles apart....and sitting in that
position is going to be rough on you in a crash.
Sent: Wednesday, December 14, 2005 8:59 PM
Subject: 3rd seat
Mike Betti
771E
3rd seat
If need be bend the rail to fit the transition and rivet it down to as many
bulkheads as you can catch. All the Rebels are that way for the front seats!
Another option is what Bob White is (having me) putting into his Elite. Got
a nice boat seat that has quick connect slider rails. Putting one set of
mounting brackets in behind the co-pilot seat and a spare set back in the
tailcone to snap it into when not needed and wanting to carry baggage. Seat
belt attached to the seat frame so it comes out with it. I would rather
belts attached to fus structure...but his call.
Sent: Thursday, December 15, 2005 10:10 PM
Subject: Re: 3rd seat
Wayne,
What do you think, if I just want to add a 3rd seat does it work out ok to
have it behind the right seat only, kind of like you explained here? Add a
set of rails right behind the copilot. I have to look but I think the
rails
would be sitting on tail cone skin which is at a slight angle to the
cabin,
wouldn't I want to shim them to make level?
Mike Betti
771E
On 12/14/2005 5:08 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> I could sit in the back of mine before I upholstered the seats. My
daughters
-> can still sit back there..20 and 17 yrs old and about 5' 6 or so. I
have/had
-> four fully adjustable seats in mine using a second seat of MAM seats
-> rails (and full shoulder/lap harnesses). I removed one seat when I went
-> floats to get rid of 10 lbs.... knowing it couldnt' be used for
anything
but
-> baggage retention.
-> The Elite is a little deeper in the rear area..so that's a plus.
-> I would not want to sit sideways for anything but a quick shuttle from
one
-> field to another that where a few miles apart....and sitting in that
-> position is going to be rough on you in a crash.
-> Wayne
-> From: "Mike Betti" <mbetti@up.net>
-> Sent: Wednesday, December 14, 2005 8:59 PM
-> Subject: 3rd seat
-> > After seeing Bob's 3rd seat I was wondering is it as practical to put
in
-> the Elite? I don't plan on going on floats anytime soon and using a
180hp.
-> Is there really enough allowance to create a 4 seat rebel and make it
work?
-> What size person goes in that back seat or 3rd seat?
-> > Mike Betti
-> > 771E
-> > List archives located at: https://www.dcsol.com/login
mikebetti
3rd seat
Post by mikebetti » Sat Feb 18, 2012 2:33 pm
Wayne,
set of rails right behind the copilot. I have to look but I think the rails
would be sitting on tail cone skin which is at a slight angle to the cabin,
Mike Betti
771E
daughters
have/had
-> four fully adjustable seats in mine using a second seat of MAM seats and
-> rails (and full shoulder/lap harnesses). I removed one seat when I went to
-> floats to get rid of 10 lbs.... knowing it couldnt' be used for anything
but
-> I would not want to sit sideways for anything but a quick shuttle from one
-> Wayne
-> > After seeing Bob's 3rd seat I was wondering is it as practical to put in
-> the Elite? I don't plan on going on floats anytime soon and using a 180hp.
-> Is there really enough allowance to create a 4 seat rebel and make it work?
-> > Mike Betti
-> > 771E
