Good morning all.
As per the assembly manual, just pulled a rag soaked in "Tube Seal" through the rudder and elevator spars.
Pretty goopy stuff.
so I figure that when it comes time to chromate the spar ends that accept the spar caps, the added shear bonus of the chromate will be lost because of a less-than-perfect bond between the spar cap barrel, and the end of the spar, due to the oily "Tube Seal."
Any ideas on what to use to clean the "tube seal" just from the ends of the spar so that the chromate will bond to clean dry metal on the spar cap and the the end of the spar itself??
Thanx all
Brian
779R
Rebel Spar Caps
Rebel Spar Caps
Acetone...like everything else here forward!
Sent: Friday, December 02, 2005 10:58 AM
Subject: Rebel Spar Caps
through the rudder and elevator spars.Good morning all.
the spar caps, the added shear bonus of the chromate will be lost becausePretty goopy stuff.
the spar so that the chromate will bond to clean dry metal on the spar capAny ideas on what to use to clean the "tube seal" just from the ends of
Thanx all
Brian
779R
Rebel Spar Caps
I just waited untill the rudder and elevators were finished then used an eye
dropper to put tube seal into the spar through the hinge bolt hole, put the
bolt in and slosh it around.
Jesse
Jesse
Subject: Re: Rebel Spar Caps
Date: Sat, 3 Dec 2005 11:21:46 -0500
As per the assembly manual, just pulled a rag soaked in "Tube Seal"acceptPretty goopy stuff.
spar, due to the oily "Tube Seal."the spar so that the chromate will bond to clean dry metal on the spar capAny ideas on what to use to clean the "tube seal" just from the ends of
and the the end of the spar itself??Thanx all
Brian
779R
Rebel Spar Caps
Thanx Wayne, Thanx Jesse
Brian
Sent: Saturday, December 03, 2005 9:14 AM
Brian
eye
Jesse
Brian
779R
