Spring gear carry through
Mike Betti
Post by Mike Betti » Sat Feb 18, 2012 10:35 am
I'm full of questions today,
Does anyone know what the angle or the dimension is that needs to be cut
off of the front 2" carry through square tube on each side to match
needed profile of body? I would like to cut it before mounting rather
than having to deal with it in place. The manual says to cut it but
doesn't give any reference of how much.
Mike Betti
771E
Alan Hepburn
Post by Alan Hepburn » Sat Feb 18, 2012 10:35 am
Take it off the forward fuselage floor panel.
Al
Mike Betti
I never thought to look there,
Sent: Saturday, June 04, 2005 8:56 PM
Subject: Re: Spring gear carry through
** Check your subject, does it still reflect the message? **
Al
Bob Andrews
Post by Bob Andrews » Sat Feb 18, 2012 10:35 am
Mike,
I'll get the angle measurement tomorrow off 612e, and post it. Mine were
cut to the angle of the carry through I took out that was wrecked ... from
what I can tell, it just needs to be able to make the forward side skin
angle change forward of the door post. Anyway, I'll send you a good angle
tomorrow.
Cheers, Bob 612e
Mike Betti
Sent: Saturday, June 04, 2005 4:42 PM
Subject: Spring gear carry through
Mike Betti
771E
Mike Betti
Post by Mike Betti » Sat Feb 18, 2012 10:38 am
Ok thanks, Al told me it is 5/8" and that looks about right. How about that
forward floor skin, does it attach with one row of rivets in the front fus5?
I'm not sure on its location. The manual just says cleco it on. Well, the
holes in the front fus5 are already at no.11 across the bottom per earler
pages of manual so it doesn't just cleco on. Also the manual says to rivet
the main floor to the bottom of the fus5 a while back also, but I didn't.
I like your website!
Mike Betti
Sent: Sunday, June 05, 2005 10:43 PM
Subject: RE: Spring gear carry through
Mike,
tomorrow.
Cheers, Bob 612e
Mike Betti
Mike Betti
771E
Bob Andrews
Post by Bob Andrews » Sat Feb 18, 2012 10:38 am
Mike,
Thanks on the website. I totally spaced out getting the angle measurement
for you today ... my bad ... was working on a C150 just a few feet away from
it too. But scratching a wrinkle in my brain says 5/8" measured from the
leading outboard edge of the forward carry through ... and snapping a line
across the top to the aft edge of the same 2x2 should be a good angle to
clear the forward side skin. Had Boy Scouts tonight ... and camped all
weekend ... plan to be back on the Elite tomorrow after work ... will verify
that 5/8" is a good number ... that is ... unless you've already cut it by
then (hehehe).
Bob 612e
Mike Betti
Sent: Monday, June 06, 2005 7:05 PM
Mike Betti
Mike,
tomorrow.
Cheers, Bob 612e
Mike Betti
Mike Betti
771E
mbetti
Post by mbetti » Sat Feb 18, 2012 10:38 am
Thank, I will be cutting it in a couple days.
Mike,
then (hehehe).
Bob 612e
Mike Betti
Mike Betti
Mike,
tomorrow.
Cheers, Bob 612e
Mike Betti
Mike Betti
771E
Bob Andrews
Mike,
5/8" (as described below) is a good number ... exactly what mine is.
Bob 612e
Sent: Monday, June 06, 2005 8:44 PM
Mike,
then (hehehe).
Bob 612e
Mike Betti
Mike Betti
Mike,
tomorrow.
Cheers, Bob 612e
Mike Betti
Mike Betti
771E
Mike Betti
Sent: Tuesday, June 07, 2005 6:27 PM
Mike,
Bob 612e
Mike,
from
verify
then (hehehe).
Bob 612e
Mike Betti
that
fus5?
Mike Betti
Mike,
from
angle
tomorrow.
Cheers, Bob 612e
Mike Betti
Mike Betti
771E
steve whitenect
Post by steve whitenect » Sat Feb 18, 2012 10:38 am
A buddy of mine cut his a 5/8 and ended up replacing it. Just be sure about
this before you cut.
Steve W
Date: Tue, 7 Jun 2005 19:30:51 -0500
Mike,
Bob 612e
Mike,
measurement
from
line
verify
by
then (hehehe).
Bob 612e
Mike Betti
that
fus5?
earler
rivet
didn't.
Mike Betti
Mike,
were
from
angle
tomorrow.
Cheers, Bob 612e
Mike Betti
cut
Mike Betti
771E
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:38 am
Think that's why MAM got smart and redimensioned the saddle location and
moved them inboard a tad..awhile ago...to increase the edge distance for the
front saddle bolt.
Sent: Tuesday, June 07, 2005 8:57 PM
about
Steve W
Mike,
Bob 612e
Mike,
measurement
away
from
line
all
verify
it
by
then (hehehe).
Bob 612e
Mike Betti
that
fus5?
earler
rivet
didn't.
Mike Betti
were
skin
cut
Bob Andrews
Here's a view of the edge distance your referring too Wayne ... the saddle
will overhang the carry through some on the forward hole.
http://www.aacnet.com/elite/3-06-05/DSC03167.JPG
http://www.aacnet.com/elite/3-06-05/DSC03169.JPG
Since only the left side of the fuselage took damage, the replacement carry
throughs were cut and drilled to match the ones that were initially
installed. Only change made to the carry throughs was the aluminum blocks
replacing the 2x2 angle pieces and squash tubes.
Moving the saddle holes inboard (while keeping the angle cut the same) would
indeed buy more edge distance for the fwd saddle bolt hole. Wayne, how much
was the saddle moved?
Bob 612e
Sent: Tuesday, June 07, 2005 7:06 PM
front saddle bolt.
about
Steve W
Mike,
Bob 612e
Mike,
measurement
away
from
line
all
verify
it
by
then (hehehe).
Bob 612e
Mike Betti
that
fus5?
earler
rivet
didn't.
Mike Betti
were
skin
cut
Can't remember. I printed out the manual changes and threw them in the Elite
Fuselage manual I have in the shop. The manual changes are in the tech
section of the Murphy website.
Sent: Tuesday, June 07, 2005 10:42 PM
carry
would
much
Bob 612e
front saddle bolt.
about
Steve W
measurement
away
from
line
angle
all
will
it
by
about
front
Well,
the earler rivet didn't.
Mine
were
skin
good
Of
be
cut
rather
steve whitenect
I cut mine off at 5/8's but luckly didn't have the holes drilled. That's
all I did- just moved the three holes in I believe about 3/8's of an inch
and ended with an acceptable edge distance.
Steve W. Rebel 637
Date: Tue, 7 Jun 2005 21:06:14 -0400
front saddle bolt.
about
Steve W
measurement
away
from
line
angle
all
will
it
by
about
front
Well,
Mine
were
skin
good
Of
be
cut
rather
