nylon washers
nylon washers
Where do you get the nylon washers called for in the elevator/rudder hinge?
I didn't get any with my kit. Are they an AN part, or hardware store?
Thanks.
Jesse
Thanks.
Jesse
nylon washers
Jesse, did I not throw a dozen in of my thrust washers?? MAM used to have
nothing there, then bought about 2000 from me and then switched to something
inferior in my mind. Give me your mailing address again and I send you some.
Sent: Monday, April 11, 2005 11:36 AM
Subject: nylon washers
hinge?Where do you get the nylon washers called for in the elevator/rudder
Thanks.
Jesse
nylon washers
I could use some also
Would be more than happy to pay for them
Keith B. Oliver
ELITE N654ME (reserved)
Farmingdale, Maine
Sent: Monday, April 11, 2005 12:41 PM
Subject: Re: nylon washers
Keith B. Oliver
Farmingdale, Maine
Thanks.
Jesse
nylon washers
Jesse bought a whole airplane kit from me and why I said I'd send him some
N/C......
As previously posted......anyone that wants them just send me $5 >CASH< and
your address and I will send you a dozen. US folks US dollars and Canadian
folks CDN dollars, as this will cover the higher postage rate to the USA.
These are only for the Rebel though TTBOMKnowledge, so Keith I'm not sure if
you need them. The washers themselves are about 2" OD with a 3/8 ID hole
that fits the hinge bushing perfectly. They are about 0.032/0.040 thick and
made of nylon 6. You will never wear them out....OEM usage was the thrust
washer for TRW seatbelts, to keep the recoil spring from wearing thru the
Polypro case.
On the Rebel they are used between the hinge brackets and the
elevator/rudder spar tubes end plugs and the rivets holding the push pull
horns on. The rudder is absolutely critical as without the washer in place
the rivets will chew their way through the lower hinge bracket thanks to
gravity.
Wayne O'Shea
1516 Alvin Williams Rd
Penetanguishene, Ontario
L9M-2C1
Sent: Monday, April 11, 2005 4:22 PM
Subject: RE: nylon washers
N/C......
Polypro case.
gravity.
Wayne O'Shea
L9M-2C1
somethingI could use some also
Keith B. Oliver
Farmingdale, Maine
some.inferior in my mind. Give me your mailing address again and I send you
hinge?Where do you get the nylon washers called for in the elevator/rudderI didn't get any with my kit. Are they an AN part, or hardware store?
Thanks.
Jesse
nylon washers
BTW, the exact dimensions for those that may have a need, OD = 1.85". ID
hole = 0.3985" and thickness is 0.042"
Sent: Monday, April 11, 2005 7:38 PM
andJesse bought a whole airplane kit from me and why I said I'd send him some
N/C......
ifyour address and I will send you a dozen. US folks US dollars and Canadian
andyou need them. The washers themselves are about 2" OD with a 3/8 ID hole
havemade of nylon 6. You will never wear them out....OEM usage was the thrust
Polypro case.
gravity.
Wayne O'Shea
L9M-2C1
Keith B. Oliver
Farmingdale, Maine
somethingnothing there, then bought about 2000 from me and then switched tosome.inferior in my mind. Give me your mailing address again and I send youWayne
Thanks.
Jesse
nylon washers
Do they sit on top of the rivets in the horn end plug, or do you cut down
the outside diameter on that one so they go inside the rivets?
Date: Tue, 12 Apr 2005 21:48:30 -0400
someJesse bought a whole airplane kit from me and why I said I'd send himandN/C......
As previously posted......anyone that wants them just send me $5 >CASH<Canadianyour address and I will send you a dozen. US folks US dollars andUSA.folks CDN dollars, as this will cover the higher postage rate to thesureThese are only for the Rebel though TTBOMKnowledge, so Keith I'm not
ifandyou need them. The washers themselves are about 2" OD with a 3/8 ID hole
that fits the hinge bushing perfectly. They are about 0.032/0.040 thickthrustmade of nylon 6. You will never wear them out....OEM usage was thethewasher for TRW seatbelts, to keep the recoil spring from wearing thrupullPolypro case.
elevator/rudder spar tubes end plugs and the rivets holding the pushplacehorns on. The rudder is absolutely critical as without the washer inhavethe rivets will chew their way through the lower hinge bracket thanks to
gravity.
Wayne O'Shea
L9M-2C1
Keith B. Oliver
Farmingdale, Maine
Jesse, did I not throw a dozen in of my thrust washers?? MAM used tostore?somethingnothing there, then bought about 2000 from me and then switched tosome.inferior in my mind. Give me your mailing address again and I send youWayne
hinge?
nylon washers
The main idea is to keep those rivets from wearing through your hinge
bracket...so YES they get left full size to cover the rivets.
Sent: Tuesday, April 12, 2005 10:15 PM
holeDo they sit on top of the rivets in the horn end plug, or do you cut down
CASH<From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
someJesse bought a whole airplane kit from me and why I said I'd send himN/C......
As previously posted......anyone that wants them just send me $5andCanadianyour address and I will send you a dozen. US folks US dollars andUSA.folks CDN dollars, as this will cover the higher postage rate to thesureThese are only for the Rebel though TTBOMKnowledge, so Keith I'm not
ifyou need them. The washers themselves are about 2" OD with a 3/8 ID
thickthat fits the hinge bushing perfectly. They are about 0.032/0.040
toandthrustmade of nylon 6. You will never wear them out....OEM usage was thethewasher for TRW seatbelts, to keep the recoil spring from wearing thrupullPolypro case.
elevator/rudder spar tubes end plugs and the rivets holding the pushplacehorns on. The rudder is absolutely critical as without the washer inthe rivets will chew their way through the lower hinge bracket thanks
youhavegravity.
Wayne O'Shea
L9M-2C1
something
elevator/ruddersome.
store?
nylon washers
I thought maybe you could use a couple to get above the rivets, but that's
easier.
Jesse
easier.
Jesse
Date: Tue, 12 Apr 2005 22:22:29 -0400
downDo they sit on top of the rivets in the horn end plug, or do you cutIDthe outside diameter on that one so they go inside the rivets?
BTW, the exact dimensions for those that may have a need, OD = 1.85".himhole = 0.3985" and thickness is 0.042"
holeCASH<someand Canadian USA. sure
ifthickthruand thrustthanksthe pull place
toOftoyouhaveelevator/rudder-----------------------------------------------------------------store?-----------------------------------------------------------------
Nylon Washers
Dale, Dave and Keith...your washers hit the mail box this morning. Let me
know when they arrive oifa@irishfield.on.ca
