Hello!
In the files, I have saw pictures of wing access cover with the doubler inside of the wing. That picture have put trouble in my life! Nowhere in the manual they say to put it inside and with the way hole ares dones, I have always imagine the doubler was suppose to be outside! Is it just a modification (nice one) that someone have done or it should be done like that?
Jean
Rebel 747R
wing access cover
Jones, Michael
wing access cover
jean
if wing is open doublers can go inside, looks better from outside this way,
cover plate covers a lot of rivets
if wing closed doublers might have to go on outside, might
i have document from Murphy that shows how to do circular doublers with
closed wing
will get document scan and post if you want
mike#007
Jean Poirier
Sent: Monday, March 07, 2005 1:26 PM
To: rebel builder
Subject: wing access cover
Hello!
that?
Jean
Rebel 747R
closed wing
mike#007
Jean Poirier
To: rebel builder
Hello!
that?
Jean
Rebel 747R
Jean Poirier
wing access cover
Hello Mike
Wing is close and the doubler is already rivet from the outside. Cover is
done with "rivnut" system to hold them. Look is not too bad, but not
"clean" as inside doubler. Too late for the right wing. Question will be
left one cleaner or symitric to the right one..... How fit the skin at the
edge of the doubler in the spar area? Coupled of months ago, there was a
good aticle too in the Kitplane magasine on how make access hole. Thanks
for all
Jean
Rebel 747R
Sent: Monday, March 07, 2005 1:36 PM
Subject: RE: wing access cover
for all
Jean
Rebel 747R
jean
way,
closed wing
mike#007
Jean Poirier
To: rebel builder
Hello!
in
that?
Jean
Rebel 747R
wing access cover
There are at least two ways to do this with the doubler on the inside.
My preferred method is to make an oval opening and cover. Then the
doubler will slip inside. The second way is to a make an angle cut in
one side of the round doubler and that is how the MAM bulletin shows it
being done. For an opening that already has the doubler on the outside
you could perhaps try a cover about 3/8" larger radius than the doubler
with a lip/flange/slight bend in the outer 1/4"
Jean Poirier wrote:
Cover isHello Mike
will bedone with "rivnut" system to hold them. Look is not too bad, but not
at theleft one cleaner or symitric to the right one..... How fit the skin
was aedge of the doubler in the spar area? Coupled of months ago, there
for all
Jean
Rebel 747R
Dale Fultz
wing access cover
Hi , What issue was that in Kitplanes magazine would like to find it . Just
subscribed to it . Thanks Dale
Sent: Monday, March 07, 2005 3:56 PM
Subject: Re: wing access cover
beHello Mike
theleft one cleaner or symitric to the right one..... How fit the skin at
Nowhereedge of the doubler in the spar area? Coupled of months ago, there was a
for all
Jean
Rebel 747R
jean
way,
closed wing
mike#007
Jean Poirier
To: rebel builder
Hello!
Iin
ahave always imagine the doubler was suppose to be outside! Is it just
that?
Jean
Rebel 747R
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.6.2 - Release Date: 3/4/05
