nav strobe lights
Jones, Michael
nav strobe lights
hi all
i am doing my wiring diagram now and can wire nav strobe lights two ways
1. 1 switch for both, switch goes off-strobes-nav, trouble is cant run nav
lights without strobes on, is this a problem
2. 2 switches , one for strobes on-off and one for nav lights on-off
any suggestions as to which is a better way to wire these
mike#007
mike#007
nav strobe lights
Hi Mike !
I would go with #2 - it is strongly recommended to turn strobes
off if in cloud, which could happen at night .... ;-^)
In any case, 2 switches would give more flexibility, in case of
electrical problems.
.......bobp
.......bobp
hi all
mike#007
Scott Aldrich
nav strobe lights
Mike,
There will be time you don't want the strobes on but need the navs on. I
wouldn't wire it with one switch unless you could reverse the order so nav
on before strobes.
If you are talking the white high intensity strobes, generally guys leave
these off on the ramp at night to not drive everyone blind and only turn on
when taking the active. There will also be times when you want to turn them
off in the air when the flash is bouncing off haze/clouds and driving you
crazy.
For me it is two switches. (or three if you have a rotating beacon)
Scott
on before strobes.
crazy.
Scott
Jones, Michael
Sent: Wednesday, February 23, 2005 1:18 PM
To: Rebel-Builders EMIAL (E-mail)
Subject: nav strobe lights
hi all
mike#007
Alan Hepburn
nav strobe lights
Have two switches. You may want to turn the strobes off on the ground to
avoid blinding people, and it's advisable to turn them off when flying in
cloud, snow at night, etc.
Al
Al
N.Smith
nav strobe lights
Hi Mike
I've copied an idea from work...
I'm planning on a single 3 position switch, centre (center :-) ) off, down
Nav only, up Nav and strobe together.
That will save a bit of panel space, although still use 2 CB's for the
cct's.
Nigel
745E
Scott Aldrich
Sent: 23 February 2005 21:16
Subject: RE: nav strobe lights
Mike,
on before strobes.
crazy.
Scott
cct's.
Nigel
745E
Scott Aldrich
Mike,
on before strobes.
crazy.
Scott
Jones, Michael
hi all
mike#007
Scott Aldrich
nav strobe lights
Yes, true, and the FAA wants us to turn it on before aircraft movement
and/or engine start.
Probably not a lot of them on homebuilt since they are not "required" and
cost money..
Scott
cost money..
Scott
Jones, Michael
Sent: Thursday, February 24, 2005 11:52 AM
To: 'rebel-builders@dcsol.com'
when i did my training i was taught that before an engine starts the
beacon
must be turned on to warn others of an engine about to start, seem to
recall
hearing this even for airliners, is this true, so why does nobody have
beacons on their kit planes
mike
Sent: Thursday, February 24, 2005 1:27 PM
Subject: Re: nav strobe lights
2 Switches Mike, without at doubt. Nav lights on right after start up and
strobes not on till you take the active. Also redundence in case a switch
fries/jams...you don't want both on the same switch even if it's a double
pole double throw, or you could find yourself in a night situation with no
Nav's or strobes.
To: "Rebel-Builders EMIAL (E-mail)" <rebel-builders@dcsol.com>
Sent: Wednesday, February 23, 2005 3:17 PM
navhi all
1. 1 switch for both, switch goes off-strobes-nav, trouble is cant runlights without strobes on, is this a problem
mike#007
nav strobe lights
Nav's or strobes.
Nav's or strobes.
hi all
mike#007
Jones, Michael
nav strobe lights
when i did my training i was taught that before an engine starts the beacon
must be turned on to warn others of an engine about to start, seem to recall
mike
Nav's or strobes.
mike
Nav's or strobes.
hi all
mike#007
Ryan Mowat
nav strobe lights
Interesting to note in Canada you are not to turn the strobes on until
line up checks - par of the CAR's. Nav's on and beacons on with engine
startup.
Ryan Mowat, P.Eng.
30528 1A Greatnorthern Ave
Abbotsford, BC V2T 6H4
(604) 556-7222 (ext 307), (604) 556-7215 (Fax)
Scott Aldrich
Sent: Thursday, February 24, 2005 11:12 AM
cost money..
Scott
startup.
Ryan Mowat, P.Eng.
Scott Aldrich
cost money..
Scott
and-----Original Message-----
Jones, Michael
beacon
recall
mike
switchstrobes not on till you take the active. Also redundence in case a
doublefries/jams...you don't want both on the same switch even if it's a
with nopole double throw, or you could find yourself in a night situation
waysNav's or strobes.
hi all
run1. 1 switch for both, switch goes off-strobes-nav, trouble is cant
----------------------------------------------------------------------navlights without strobes on, is this a problem
mike#007
recipientNOTICE - This message is the property of HATCH. It may also be
disseminate,of this message you are hereby notified that you must not
