New Builder questions
Post by Mike Davis » Fri Feb 17, 2012 5:26 pm
Received: (qmail 7082 invoked by uid 0); 7 Sep 1999 19:35:05 -0000
Message-ID: <19990907193505.7081.qmail@hotmail.com>
Received: from 134.134.248.18 by www.hotmail.com with HTTP;
Tue, 07 Sep 1999 12:35:05 PDT
X-Originating-IP: [134.134.248.18]
Subject: New Builder questions
Date: Tue, 07 Sep 1999 12:35:05 PDT
Mime-Version: 1.0
Content-Type: text/plain; format=flowed
All,
While we are awaiting our rebel kit we are trying to "tool up". We have our
bench built and are getting ready to put in an order at Aircraft Spruce for
some tools. Some questions:
1. Does anyone have specific Aircraft spruce part numbers for:
a. Pneumatic riviter w/die sets?
b. Dimple tools
c. Bucking bars.
2. Amount of clecos to order (all 3 sizes)!
AS&S is way cheaper than other places I found but I want to make sure I
order the right tools so we can START! Being brand new to Metal airplanes
makes looking through the catalog pretty confusing. If there is anymore
last chance advise PLEASE feel free to vent it out!
B,B&R Amendala
Rebel kit#669
Olympia, WA
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
Received: from tim - 209.119.137.69 by email.msn.com with Microsoft SMTPSVC;
Tue, 7 Sep 1999 13:53:37 -0700
Reply-To: <tlcarter@msn.com>
To: "'Murphy Rebel Builders List'" <murphy-rebel@dcsol.com>
Subject: RE: New Builder questions
Date: Tue, 7 Sep 1999 13:58:23 -0700
Message-ID: <000e01bef973$bbb1cea0$14640a0a@tim>
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3 (Normal)
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2314.1300
Importance: Normal
In-Reply-To: <19990907193505.7081.qmail@hotmail.com>
Return-Path: tlcarter@email.msn.com
Hi Ryan:
If you are building a standard Rebel, there will be no need for a rivet set,
dies and bucking bars. I don't know if this is a tool requirement on the
Rebel Elite and Super Rebel.
Nonetheless, I bought a complete set from ATS for about $200. Included gun,
dies, bars, regulator, springs, etc. and a carry case. I have used it
twice, and that was on my Cub.
www.aircraft-tool.com
You can get a complete set of the best stainless dimple dies and squeezer
from
www.airbolt.com
I have 350-400 ea. 3/32" and 1/8" and about 50 3/16" full length, about 50
ea. 3/32", 1/8" and 3/16" short length, and 20 mid-reach spring clamps (a
must). I used most of the full length up at once on the wings, because I
built farther in clecos than the manual calls for. this is a good thing as
far as I'm concerned, because if you rivet when the manual tells you to, you
will find yourself removing rivets for one reason or another.
Hope that helps.
Tim
#438R
Sent: Tuesday, September 07, 1999 12:35 PM
All,
b. Dimple tools
c. Bucking bars.
B,B&R Amendala
Rebel kit#669
Olympia, WA
Received: from [154.11.82.232]
(helo=ip232.mississauga.dialup.canada.psi.net)
by smtp1.interramp.com with smtp (Exim 1.90 #1)
for murphy-rebel@dcsol.com
id 11OSNW-0004Ui-00; Tue, 7 Sep 1999 17:02:10 -0400
Mime-Version: 1.0
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Subject: Re: New Builder questions
Message-Id: <E11OSNW-0004Ui-00@smtp1.interramp.com>
Date: Tue, 7 Sep 1999 17:02:10 -0400
You could do a LOT worse than ordering the BASIC TOOL KIT from Murphy !!
They give you all the basic tools, and enough clecoes to get started...
including a set of dimple dies.
Otherwise, you may end up buying stuff you can't use - you DO NOT need
the type of rivetter that uses dies, NOR bucking bars !! The Rebel is built
with AVEX blind rivets - they are PULLED rivets, which you can drive by
yourself - you don't need someone to buck them.
BTW, have you checked USA Tools, or Cleaveland Tools ??
----------------------------orig.-------------------------------------------
At 12:35 PM 9/7/99 PDT, you wrote:
All,
our
b. Dimple tools
c. Bucking bars.
B,B&R Amendala
Rebel kit#669
Olympia, WA
Received: from computer (dial94.b2.tnt2.wa.freei.net [209.162.149.94])
by mail.wa.freei.net (Postfix) with SMTP id 7555531933
for <murphy-rebel@dcsol.com>; Tue, 7 Sep 1999 16:55:42 -0700 (PDT)
Message-ID: <002a01bef98c$90b87d20$5e95a2d1@computer>
References: <19990907193505.7081.qmail@hotmail.com>
Date: Tue, 7 Sep 1999 16:48:21 -0700
MIME-Version: 1.0
X-Priority: 3
X-Mailer: Microsoft Outlook Express 5.00.2314.1300
.. Pneumatic riviter Harbor Freight #00167-3AEA
$39.95 1800-423-2567 ( free shipping if over $50) www.harborfreight.com
.. Dimple tools Murphy less than $10.00 I think
Bucking bars. Not needed
Chuck Bailey
R176
All,
our
for
b. Dimple tools
c. Bucking bars.
B,B&R Amendala
Rebel kit#669
Olympia, WA
Received: from earthlink.net (ip143.seattle11.wa.pub-ip.psi.net
[38.28.67.143])
by scaup.prod.itd.earthlink.net (8.9.3/8.9.3) with ESMTP id KAA01451;
Wed, 8 Sep 1999 10:38:04 -0700 (PDT)
Message-ID: <37D69FFF.D5284CE4@earthlink.net>
Date: Wed, 08 Sep 1999 10:42:26 -0700
X-Mailer: Mozilla 4.5 (Macintosh; I; PPC)
X-Accept-Language: en
MIME-Version: 1.0
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
CC: Chuck Bailey <baileyca@wa.freei.net>
References: <000e01bef973$bbb1cea0$14640a0a@tim>
Content-Type: text/plain; charset=iso-8859-1; x-mac-type="54455854";
x-mac-creator="4D4F5353"
Content-Transfer-Encoding: quoted-printable
X-MIME-Autoconverted: from 8bit to quoted-printable by
scaup.prod.itd.earthlink.net id KAA01451
Ryan:
After ordering my kit in July 99, I interviewed some local Rebel builde=
rs to
get some ideas on what tools and equipment were required. After all not=
es
were taken, I decided to make a simple "equipment needed" spread sheet =
in
Excel to sort out the best prices available from the best supplier.
As progress continues on my bomber, I may find that I need more stuff o=
r say
to myself..."dang, why did I buy that tool?".
Most of these tools are new, as my previous aircraft building project
required different type of assortment. Here is a list of major tools I=
came
up with for this project:
Hand Riveter
Pro-Snip or Weiss Cutters (left hand)
Pro-Snip or Weiss Cutters (right hand)
Clecos: 400@ 3/32
Clecos: 400@ 1/8
Clecos: 50@ 3/16
Clecos Side Clamp: 6 @ 1/2
Clecos Side Clamp: 6@ 1
90 degree Drill (Tight Fit kit)
Digital Level 24" (SmartTool)
Rivet Spacer
Edge Marker Block
Dimple tool
Pop Rivet Dimplers: 3/32
Pop Rivet Dimplers: 1/8
Fluting Pliers (plier type)
Fluting Pliers (vice grip type)
Stretcher/Shrinker
Drill Press
Digital Calipers
Band Saw
Misc. Drill bits
Misc. Files
Basic hand tools etc.
When I was building my Long-EZ, I did commerce almost exclusively with
Aircraft Spruce. Nowadays with the business competition environment and=
tight
money, it pays (literally) to shop around.
Here are some suppliers I conjured up (I know there are more, but I did=
n=92t
want to make it my life=92s work).
Remember to get current prices and shipping charges. And search the web.
(Note: The below also have email addresses):
Aircraft Spruce & Specialty Co. 1-800-824-1930 http://www.aircraft?spru=
ce.com
Aircraft Tool Supply Co. 1-800-248-0638 http://www.aircraft-tool.com
Avery Tool Co.
Brown Aviation Tool Supply 1-800-587-3883 http://www.browntool.com
Chief Aircraft 1-800-447-3408 http://www.chiefaircraft.com
Grizzly Industrial 1-800-523-4777 http://www.grizzlyindustrial.com
Harbor Freight Co. 1-800-423-2567 http://www.harborfreight.com
Murphy Aircraft Co. 604-792-5855 http://www.murphyair.com
Tool Crib 1-800-358-3096 http://www.toolcribofthenorth.com
Wicks Aircraft Supply 1-800-221-9425 http://www.wicks.com/aircraft
Electronic Proportion Scale www.balances.com
Reamers www.kbctools.com
Dimpled Nutplates 800-736-4123 www.airbolt.com
I hope this helps in your quest for building the perfect Rebel. Have a =
great
time building and keep us posted on your progress.
Blue Skies,
Terry Dazey
Long-EZ N86TD
Murphy Rebel #662
PS. We also have a Pacific Northwest Rebel Builders Web Site that Chuck B=
ailey
and Chuck Scourpa started (they are going to have plenty of pictures
eventually). One of the two Chucks (is that Chuck squared?) can fill you =
in on
how to log on etc.
All,
While we are awaiting our rebel kit we are trying to "tool up". We =
have
our
bench built and are getting ready to put in an order at Aircraft Spr=
uce
for
some tools.
<snipped some stuff that has already been answered>
B,B&R Amendala
Rebel kit#669
Olympia, WA
Joel Jacobs
Post by Joel Jacobs » Fri Feb 17, 2012 5:26 pm
To: (Murphy Rebel Builders List) <murphy-rebel@dcsol.com>
Cc: Chuck Bailey <baileyca@wa.freei.net>
Sent: Wednesday, September 08, 1999 1:42 PM
Digital Calipers
I find that if I get the cheap $20 dial calipers I get much less upset when
I drop them on the cement floor...
Joel
Terry Dazey
Post by Terry Dazey » Fri Feb 17, 2012 5:26 pm
Joel:
Do you drop the calipers because you are holding them with one hand and
scratching your head with the other while trying to determine which teeny
line
the tiny pointer is pointing to? =:-)
We could probably start a pretty good dialogue if I said something like
"analog gages in the cockpit are best ...and discrete discontinuous digital
data displays everywhere else". But then I would be hypocritical, because I
have several (not flight critical) digital gages in my Long-EZ instrument
panel .... a clock, stereo and OAT readout.
Blue Skies,
Terry Dazey
Long-EZ N86TD
Rebel #662
Digital Calipers
when
Joel
Charles Skorupa
Post by Charles Skorupa » Fri Feb 17, 2012 5:26 pm
The address is:
http://beta.communities.msn.com/NWRebel ... alAircraft
It is an experiment just getting started and is not meant to replace this
forum. Don't know if it will survive or not. Just playing around with MSN
Communities. For now the emphasis is on posting photos and adding a little
dialog. All are welcome to join. I have a bunch of Elite phots yet to post
that may be of interest to the group.
Chuck Skorupa
Rebel Elite #500
Reply-To: <murphy-rebel@dcsol.com>(Murphy Rebel Builders List)
Date: Wed, 08 Sep 1999 16:32:48 -0300
Terry, (Chuck)^2
What is the address of the new Rebel site??
Dave R
Terry Dazey wrote:
SNIP!
Bailey
in on
how to log on etc.
Joel Jacobs
Sent: Wednesday, September 08, 1999 5:30 PM
Joel:
line
No I don't have any problem reading it - and I gotta admit the digital ones
are great for relative measurements and in/mm conversions, but I have a
habit of laying them somewhere and forgetting about them until I move
something and hear the clink clink sound as they hit the floor. Then I
think 'sure am glad that wasn't a $100 digital' ;>)
Joel
Nice format! I like the fact that you can add pictures with descriptions...
you're likely to get a much bigger photo library when anyone can add a photo
themselves. I wish I knew how to develop the dynamic features like that...
I'll put a link to your site up on my Rebel site soon.
Sent: Wednesday, September 08, 1999 7:36 PM
The address is:
MSN
little
post
Chuck Skorupa
Rebel Elite #500
