I noticed while looking in the picture archives under the FUS-30 fix stuff,
which I guess is Wayne's plane because of all the green paint, that he put a
big gusset on the bottom of the rudder as well. Is this a mod also, or did
the rudder just get damaged somehow?
Jesse
Rebel rudder gusset
Rebel rudder gusset
Jesse...when flying skis and they stick and you find yourself staring out
the windshield at the ground......remember to push one rudder pedal all the
way to the floor before the tail comes back down!!! Oh Yah! You don't have
that problem in CA...most of the time!
Sent: Saturday, December 18, 2004 10:04 PM
Subject: Rebel rudder gusset
stuff,I noticed while looking in the picture archives under the FUS-30 fix
awhich I guess is Wayne's plane because of all the green paint, that he put
Jesse
Rebel rudder gusset
That's one cause.... but thought about that again. That green 'plane in
those archives pics is George Christie's that I fixed after their landing
gear departed on one side. Lower end of rudder got buckled in the event and
that was the repair for it.
Sent: Saturday, December 18, 2004 10:10 PM
Subject: Re: Rebel rudder gusset
theJesse...when flying skis and they stick and you find yourself staring out
putway to the floor before the tail comes back down!!! Oh Yah! You don't have
stuff,I noticed while looking in the picture archives under the FUS-30 fixwhich I guess is Wayne's plane because of all the green paint, that he
didabig gusset on the bottom of the rudder as well. Is this a mod also, or
Jesse
Rebel rudder gusset
Wayne,
I had to think about that one for a minute. So what happens is that when the
tail comes down hard it hits the tailwheel, and you have to "kick" it out of
the way? You'd have to be in a pretty mellow state to remember that. Is that
mostly a problem with the MAM aluminum tail spring, or can it happen with
any setup?
Jesse
any setup?
Jesse
Date: Sat, 18 Dec 2004 22:10:10 -0500
stuff,I noticed while looking in the picture archives under the FUS-30 fixputwhich I guess is Wayne's plane because of all the green paint, that he
adidbig gusset on the bottom of the rudder as well. Is this a mod also, orthe rudder just get damaged somehow?
Jesse
Rebel rudder gusset
Yes Jesse..the natural reaction is to freeze with both feet jammed against
the pedals waiting to see pieces of your prop go flying. Then when the tail
comes back down from that height, with no forward motion, the tail spring
gives enough to hit the bottom of the rudder. Can happen with either the
alum or fiberglass springs supplied with the kis. Might even happen with the
steel one that I use and recommend replacing the factory springs with. If
you push one pedal to the floor instead...the rudder will be out of the way
of the tail spring/wheel.
Sent: Sunday, December 19, 2004 12:17 PM
theWayne,
oftail comes down hard it hits the tailwheel, and you have to "kick" it out
thatthe way? You'd have to be in a pretty mellow state to remember that. Is
themostly a problem with the MAM aluminum tail spring, or can it happen with
any setup?
Jesse
haveway to the floor before the tail comes back down!!! Oh Yah! You don't
Jesse
