When hooking up the throttle or other controls, I thought I read somewhere
that I should leave a "cushion" at each end of the throw. i.e. the throttle
arm on the carburetor hits the stop before my throttle hits the stop on the
instrument panel or hits the idle stop on carb. before reaching max aft
limit on throttle?
Does this sound right?
Scott
Moose 174
Throttle cable hook up
Scott,
That is the common practice (and it is not much of a cushion - 1/4 inch is fine) in order to ensure that the carb end has full travel (lowest idle and full power) without any doubt on your part. You want to make sure that when you push forward on that throttle that you have truly "given it all she's got" at the carb end.
Rich
Do you Yahoo!?
Yahoo! Mail is new and improved - Check it out!
Rich
Do you Yahoo!?
Thanks Rich,
Scott
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rich
Dodson
Sent: Tuesday, August 17, 2004 1:52 PM
Subject: Re: Throttle cable hook up
Scott,
Rich
Do you Yahoo!?
Scott
Dodson
Scott,
Rich
Do you Yahoo!?
Hi Scott,
That's the way we did ours. Seems to work fine.
Dick Shotwell
Moose 096
N235DS
Sent: Tuesday, August 17, 2004 13:39 PM
Subject: Throttle cable hook up
Dick Shotwell
Moose 096
N235DS
throttleWhen hooking up the throttle or other controls, I thought I read somewhere
thearm on the carburetor hits the stop before my throttle hits the stop on
limit on throttle?
Scott
Moose 174
