Cable guides
David W.S. King
Cable guides
Post by David W.S. King » Sat Feb 18, 2012 12:05 pm
Does anyone know the manf or part number or have any clear pics of the
plastic cable guides?
I'm looking but can't find anything yet.
Cable guides
Post by Drew Dalgleish » Sat Feb 18, 2012 12:05 pm
I'm sure someone will let me know if I'm wrong but RU-1 seems to be a
number I remember.
Lonnie Benson
Cable guides
Post by Lonnie Benson » Sat Feb 18, 2012 12:05 pm
Sent: Monday, March 22, 2004 11:33 PM
Subject: Re: Cable guides
number I remember.
Very close Drew. Mine are marked RG-1.
Lonnie
David W.S. King
Cable guides
Post by David W.S. King » Sat Feb 18, 2012 12:09 pm
You guys have any idea if it's delrin/nylon 66/teflon or uhmw?
I have blocks of those and I can just knock out the few I need
if I was sure what they were.
of the plastic cable guides?
be a number I remember.
Lonnie
-------* To unsubscribe from this list go to:
rebel
Cable guides
Post by rebel » Sat Feb 18, 2012 12:09 pm
Hi Dave
The guide blocks are nylon. You can get them from Murphy or save the shipping
and just go to the hobby shop as the new ones that Murphy sells say DU-BRO on
the bottom. They are used to mount the landing gear on model airplanes. If
you have a kit older than one year you will find the mounting holes are
futher apart than the new ones.
Sean White
Kitplane Solution inc.
On 3/23/2004 2:27 PM, KINGDWS@SHAW.CA wrote to MURPHY-REBEL:
-> Received: by dcsol.com (Wildcat! SMTP Router v5.7.450.9b10)
-> for murphy-rebel@dcsol.com; Tue, 23 Mar 2004 12:00:26 -0900
-> Received: from ([24.71.223.10]) EHLO=pd4mo3so.prod.shaw.ca
-> by dcsol.com (Wildcat! SMTP v5.7.450.9b10) with SMTP
-> id 1196246890; Tue, 23 Mar 2004 12:00:25 -0900
-> Received: from pd5mr4so.prod.shaw.ca
-> (pd5mr4so-qfe3.prod.shaw.ca [10.0.141.168]) by l-daemon
-> (iPlanet Messaging Server 5.2 HotFix 1.18 (built Jul 28 2003))
-> with ESMTP id <0HV100LJJRNB2E@l-daemon> for murphy-rebel@dcsol.com; Tue,
-> 23 Mar 2004 13:59:35 -0700 (MST)
-> Received: from pn2ml3so.prod.shaw.ca ([10.0.121.147])
-> by pd5mr4so.prod.shaw.ca (Sun ONE Messaging Server 6.0 HotFix 1.01 (built
Mar
-> 15 2004)) with ESMTP id <0HV100137RN3ZCJ0@pd5mr4so.prod.shaw.ca> for
-> murphy-rebel@dcsol.com; Tue, 23 Mar 2004 13:59:27 -0700 (MST)
-> Received: from Holly.synergy (h24-70-223-180.ok.shawcable.net
[24.70.223.180])
-> by l-daemon (iPlanet Messaging Server 5.2 HotFix 1.18 (built Jul 28 2003))
-> with ESMTP id <0HV100LMDRNBXT@l-daemon> for murphy-rebel@dcsol.com; Tue,
-> Date: Tue, 23 Mar 2004 12:59:49 -0800
-> From: "David W.S. King" <KingDWS@Shaw.Ca>
-> Subject: Re: Cable guides
-> In-reply-to: <052f01c410ce$891a8320$45362c42@default>
-> To: murphy-rebel@dcsol.com
-> Reply-to: KingDWS@Shaw.Ca
-> Message-id: <200403231259.49717.KingDWS@Shaw.Ca>
-> Organization: Synergy Tech
-> X-Orig-MIME-version: 1.0
-> X-Orig-Content-type: text/plain; charset=iso-8859-1
-> X-Orig-Content-transfer-encoding: 7BIT
-> X-Orig-Content-disposition: inline
-> User-Agent: KMail/1.5.4
-> References: <be.82538d2.2d910dcd@aol.com>
-> <3.0.1.32.20040322233301.00e49ed0@mail.cabletv.on.ca>
-> <052f01c410ce$891a8320$45362c42@default>
-> X-Antivirus-Remover: Message was filtered through wsMailGuard (wsAV)
-> You guys have any idea if it's delrin/nylon 66/teflon or uhmw?
-> I have blocks of those and I can just knock out the few I need
-> if I was sure what they were.
-> Dave
-> On March 23, 2004 04:00 am, you wrote:
-> > ----- Original Message -----
-> > From: "Drew Dalgleish" <drewjan@cabletv.on.ca>
-> > To: <murphy-rebel@dcsol.com>
-> > Sent: Monday, March 22, 2004 11:33 PM
-> > Subject: Re: Cable guides
-> > > At 08:20 PM 3/22/2004 -0800, you wrote:
-> > > >Does anyone know the manf or part number or have any clear pics
-> > > > of the plastic cable guides?
-> > > >I'm looking but can't find anything yet.
-> > > >Dave
-> > > I'm sure someone will let me know if I'm wrong but RU-1 seems to
-> > > be a number I remember.
-> > > Drew
-> > Very close Drew. Mine are marked RG-1.
-> > Lonnie
-> > > To unsubscribe from this list go to:
-> > > https://www.dcsol.com/public/code/html-subscribe.wcx
-> > > Archives located at https://www.dcsol.com/default.htm
-> > > Archives public username "rebel" password "builder"
-> > > To contact the list admin, e-mail mike.davis@dcsol.com
-> >-------* To unsubscribe from this list go to:
-> > https://www.dcsol.com/public/code/html-subscribe.wcx
-> > Archives located at https://www.dcsol.com/default.htm
-> > Archives public username "rebel" password "builder"
Cable guides
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:09 pm
David, I never bothered to burn one to sniff it, but with 20 years plastic
experience sight tells me they're Nylon 66.
Cheers, Wayne
Sent: Tuesday, March 23, 2004 3:59 PM
At 08:20 PM 3/22/2004 -0800, you wrote: I'm sure someone will let me know if I'm wrong but RU-1 seems to
Lonnie
David W.S. King
Cable guides
Thanks Sean (and Wayne)
I kept thinking they were nylon cable clamps.
37 cents each local or $1.62 from MAM. Look at
the piture of the Dubro catalog and thats them.
Nylon landing gear straps 1/8 or 3/16
save the shipping
sells say DU-BRO on
model airplanes. If
mounting holes are
Sean White
Cable guides
Had a look at the dubro website http://www.dubro.com/DU-BRO/index.htm and
the gear "straps" at 1.05/set of 4 are not what you want. These have an open
"bottom" side (so aren't going to hold the cable up off the mounting
surface). The landing gear "blocks" pt #156 are the ones you'd want with a
true hole and gusset reinforcements. These are a whopping $2.10US/ set of
two. $1.05 each x 1.34 = $1.41each Cdn so MAM's not to far off for
handling/inventory costs for an extra 13%.
Definitely easier to walk into a local RC store and see what they have in
their parts rack though...since you don't need the bolts that they ship with
each set from Dubro!
Sent: Wednesday, March 24, 2004 2:42 AM
Subject: RE: Cable guides
save the shipping
sells say DU-BRO on
model airplanes. If
mounting holes are
Sean White
