copper pipe!
Sent: Monday, March 15, 2004 8:52 PM
Subject: Re: Primer Fittings
meThanks Wayne, before ordering the proper fittings from ACS (too bad you
don't have any) I'll try the compression fittings as you suggested. Tell
close... are those AN cones soldered to the tubing before tightened into place?
Would they solder OK to the copper tubing?
Clay
Sent: Monday, March 15, 2004 11:58 AM
Clay, had a look through my stuff and unfortunately don't have any
AN800/805-2's! 100's of -3's but no -2's :o( !
I had a really close look at the old spray primer nozzles and their tube
seating area and a matching nut versus a new $1.99 CTC brass compression
tube to npt nipple and the sealing surfaces (and mating thread) are
needandenough that if you bought a pack of sleeves and nuts (or any fitting
assembly to steal same from) pretty sure they would do the trick for youhold everything tightly and leak free.
Sent: Monday, March 15, 2004 10:09 AM
Clay, if you have the original spray style nozzles you most likely
asthecone and matching nut since the sealing surface shape is not the same
*-------------------------------------------------------------------------*anipplecompression fittings face. You can just use an 1/8" NPT compressionthefor the primers, but if you already have the proper spray style (withthelittle tube coming out of them) all the better and you should match upWillconnection properly.
Pretty sure I have a box of the AN800's but not sure about the nuts.myhave a look shortly and let you know.
Sent: Monday, March 15, 2004 12:11 PM
Subject: Primer Fittings
thesecone,union
