Mike's flaperon actuator cover
Angus McKenzie
Post by Angus McKenzie » Sat Feb 18, 2012 8:56 am
Hi Mike
Just got home from the shop and here are the dimensions.I cut the full
piece in half then trimmed the halves by nesting them to allow a 1"
mounting flange.The full width edge to edge is 4-3/4"s length is 9" but
length has yet to be trimmed for exact fit .I am going to drill out a
couple of wing rivets that the flange will cover and install C/Srivs so
it sits flat,anti-chafe tape on the underside then secure it with 5
#8PKs. Hope this helps.Also finished fitting and mounting one wing tip
and got the other partly finished.I wanted to get them on this week
before I put the floats on.
Regards, Angus
Angus McKenzie
Two and three quarters......Look forward to going flying with
you..........Angus
Sent: Wednesday, February 11, 2004 4:11 AM
Subject: RE: Mike's flaperon actuator cover
hi angus
these dims help alot, whats the insdie dim of the flange ??
Sent: Tuesday, February 10, 2004 9:39 PM
Subject: Mike's flaperon actuator cover
Hi Mike
Regards, Angus
Jones, Michael
Post by Jones, Michael » Sat Feb 18, 2012 8:56 am
hi angus
Hi Mike
Regards, Angus
