Door Latch Systems
Bill Delcambre
Door Latch Systems
Post by Bill Delcambre » Sat Feb 18, 2012 11:55 am
BlankHi guys,
What are you fellows doing for door latch systems on the SR/Moose?
Don't know if the Rebel and Elite use similar systems, but I'm thinking
there's something better than a piece of cable that you yank on. I've
seen what the 'seaplane' doors are using, but looks pretty heavy.
Alternative ideas?
Bill
Don Boardman
Door Latch Systems
Post by Don Boardman » Sat Feb 18, 2012 11:55 am
Hi Bill,
Randy and I have been looking for a door latch for some time now and have
decided to try and make the following work.
http://www.allegiscorp.com/DisplayPartA ... Id=626&gro
upElementId=1&displayTemplate=/jsp/displayDetailTemp_4.jsp&cat=Single-Point+
Slam+Latches
With the addition of some interior linkage we think it will be a good set up
for us. The latches are HEAVY, we will try to reduce some of the weight with
lightning holes in the structure.
We will be installing three all keyed alike. I like the fact that you can
leave them unlocked. I am not a big fan of locking things when not needed.
We are a few weeks from installation and will be glad to get back to the
group with some pictures when all is sorted out.
Don B.
Jones, Michael
Door Latch Systems
Post by Jones, Michael » Sat Feb 18, 2012 11:55 am
bill
if you look at pics on rebel builders site under rebel-miscellaneous and
gull wing door (about 17) you will see a paddle exterior door handle and
interior crank handle, and center bell crank, although not 100% complete it
works great and is not much weight, little fine tuning and should be perfect
and best of all it fits inside depth of the rebel door (5/8" tube)
mike#007
Sent: Tuesday, February 03, 2004 9:33 AM
Subject: Re: Door Latch Systems
Hi Bill,
Slam+Latches
Don B.
Bill Delcambre
Door Latch Systems
Thanks for the feedback, guys. I, for one, would certainly appreciate the
posting of pics of alternative installations.
Bill
Sent: Tuesday, February 03, 2004 8:32 AM
Hi Bill,
Slam+Latches
up
with
Don B.
bdelcambre
Door Latch Systems
Post by bdelcambre » Sat Feb 18, 2012 11:55 am
Thanks, Bob.
Understand your point about the convenience/utility of the cable system. Gotta agree that the K.I.S. approach is sometimes the best, for a lot of reasons. Been telling myself all along to just build the thing and don't try to 'improve' it. Therefore, instead of riveting all the door tube pieces together, I welded them. VERY rigid and stable. Came out real nice. If anyone is considering doing this, I'd recommend it. Just figured I'd look at 'improved' latch systems. All the suggestions look great. Kinda my impression that an improved latch is something that could be easily retrofitted. Probably ought to take my own advice and just build it, huh? 'Improve' it later. We'll see. You've just witnessed an example of me, writing to myself.... Now, if I'd only heed my advice.
Bill
Date: 2004/02/03 Tue PM 09:20:02 CST
Hi Bill !
For at least 4 years, I had an amphib Rebel with a wire running
from the front to back of the door, about 1" - 2" down from the top,
covered with a piece of clear fuel line. It sat on top of the
upholstered door panel, and was extremely easy to use !
When arriving on the water, if anything went wrong, I didn't
have to worry about finding & pulling any fancy handle - just swipe
anywhere along the top part of the door, pull down, and I was out !!
Maybe not too pretty, but it worked well ....
Another advantage of the cable release is it's easy to reach from
the front OR back seats - someone in the rear seats might want to open the
door (perhaps on the passenger side), without having to stand up &
lean forward to reach the front latch ... That's a BIG airplane,
and it's a LONG way forward !! :-)
The Factory Moose used the inside handle from a Mazda from
a wreckers. These plastic handles were very nice, light, and mounted
recessed into the door panels. They pulled on a small threaded rod
with hex nuts to operate the mechanism. This was a MAJOR pain, as
the rod would rotate, and the nuts would fall off - ouch ! Then
you couldn't get in or out, and you had to dis-assemble the door
to fix it !! That airplane also had a paddle handle near the
front of the door on the outside - NOT a good place for a latch
handle - put it near the BACK of the door on the outside, so
pulling helps open the door. ;-)
Spaenaur have lots of different latches and handles, some
with locks, as well as tons of other useful stuff for airplanes,
like rubber edge trim in many shapes, etc. They're here in
Kitchener, Ontario, but likely have US outlets, too ...
www.spaenaur.com
The catalogue is a couple of inches thick !!
There's a couple of back-to-back paddle latches that look very
Cessna-ish ... ;-)
On Monday 02 February 2004 04:03 pm, you wrote:
BlankHi guys,
Alternative ideas?
Bill
Door Latch Systems
Post by Bob Patterson » Sat Feb 18, 2012 11:55 am
Hi Bill !
www.spaenaur.com
Cessna-ish ... ;-)
BlankHi guys,
Alternative ideas?
Bill
Jones, Michael
Door Latch Systems
hi bill
perhaps my last post did not make it but i put 17 pics under rebel misc of
my door & handles
mike#007
From: Bill Delcambre [mailto:bdelcambre@cox-internet.com]
Sent: Tuesday, February 03, 2004 4:58 PM
Bill
Hi Bill,
Slam+Latches
up
with
Don B.
Bill Delcambre
Door Latch Systems
Thanks Mike,
I did look at your pics. Appears that you did a lot of thinking about this
system and did a great job. Thanks so much for posting the pics for all our
benefit. Yours is closest to what I'm imagining to be a good system. Looks
pretty light, reliable and user friendly. Well thought out!
Bill
Sent: Wednesday, February 04, 2004 6:18 AM
Subject: RE: Door Latch Systems
hi bill
my door & handles
mike#007
Bill
Hi Bill,
have
Slam+Latches
set
up
with
can
needed.
Don B.
Door Latch Systems
Hi Bill !
Glad I'm not the only one who 'writes/talks' to himself !!
I have the same problem - trying to do what I tell myself ... ;-) :-)
Blair Singer has a system to help with that - he calls it
the "LVMS" - Little Voice Management System. ;-) Whenever I have a
problem with that little voice that says 'change this, improve that',
I have to remind it that the object was to Get Flying, not build
"the perfect airplane" !! :-) :-)
Sounds like you're doing a great job !
Good luck with your LVMS !! :-)
On Tuesday 03 February 2004 10:41 pm, you wrote:
Thanks, Bob.
Bill
Hi Bill !
www.spaenaur.com
Cessna-ish ... ;-)
BlankHi guys,
Alternative ideas?
Bill
Door Latch Systems
Post by Mike Kimball » Sat Feb 18, 2012 11:55 am
I have both a handle and a cable on my Super Rebel. Instead of merely
hooking the cable to a fixed point at the front of the door I fashioned a
simple handle out of a piece of angle aluminum (1 x 1 I think). I held the
angle against the door with a bolt about which the angle pivots. The cable
is hooked to the angle. It's hard to describe in words (I'll post a
picture), but you can either reach forward and push down on the angle or you
can grab the cable to open the door.
SR #044
rickhm@mindspring.com
Sent: Wednesday, February 04, 2004 1:39 PM
Not that I am suggesting the wire approach is bad, but I did find some nice
handles from Wag Aero that are a flush mount externally (like the C-182
handles) and they were easy to install. The WAG part number is M-242-000.
Cost is $56 each.
Rick Muller
SR70
Sent: Feb 3, 2004 8:20 PM
Hi Bill !
www.spaenaur.com
Cessna-ish ... ;-)
BlankHi guys,
Alternative ideas?
Bill
Jones, Michael
Door Latch Systems
Post by Jones, Michael » Sat Feb 18, 2012 11:56 am
bill
i can supply part numbers and other info if you want to study door system
more. just shout
mike#007
Sent: Wednesday, February 04, 2004 10:27 AM
Thanks Mike,
Bill
hi bill
my door & handles
mike#007
Bill
Hi Bill,
have
Slam+Latches
set
up
with
can
needed.
Don B.
rickhm
Door Latch Systems
Post by rickhm » Sat Feb 18, 2012 11:56 am
Not that I am suggesting the wire approach is bad, but I did find some nice handles from Wag Aero that are a flush mount externally (like the C-182 handles) and they were easy to install. The WAG part number is M-242-000. Cost is $56 each.
Rick Muller
SR70
Hi Bill !
www.spaenaur.com
Cessna-ish ... ;-)
BlankHi guys,
Alternative ideas?
Bill
rickhm
Door Latch Systems
Will do! Give me a day!
Rick SR70
Sent: Feb 5, 2004 7:48 AM
I've looked at that latch, but couldn't get a handle on how it's made. (get
it: get a handle on the latch......) If you'd post a couple of pics of the
inside of your installation, I for one, would sincerely appreciate it!
Heck, Wayne; post yours too so that we'll have another choice. The idea
of the angle, simply hinged on the door, sounds good; easy, cheap and
fool-proof.
Bill
Sent: Wednesday, February 04, 2004 4:38 PM
Cost is $56 each.
Rick Muller
SR70
Hi Bill !
www.spaenaur.com
Cessna-ish ... ;-)
BlankHi guys,
Alternative ideas?
Bill
Bill Delcambre
Door Latch Systems
Post by Bill Delcambre » Sat Feb 18, 2012 11:56 am
fool-proof.
Bill
Cost is $56 each.
Rick Muller
SR70
Hi Bill !
www.spaenaur.com
Cessna-ish ... ;-)
BlankHi guys,
Alternative ideas?
Bill
